Upgraded from 2020.2.4 to 20202.5 - Node Details - WEB BROWSE shows the following on some devices http://{ { HrefIPAddress }}
Yes this has been fixed in 2020.2.6
That's not new to this version, its been a common bug since as far back as I can remember. At times when I was more motivated I just wrote a trigger on the nodesettings table to replace it any time that comes up with the actual ip of the node.
In the 2020.2.5 version there is a syntax error in NodeDetails.ascx.Solarwinds have added the file with following in several lines: DefaultSanitizer.SanitizeHtmlThis include the line for web browsing, which breaks the line.It is line number 224 and looks like this: <td class="Property"><a href="<%= DefaultSanitizer.SanitizeHtml(WebBrowseTemplate) %>"><%= DefaultSanitizer.SanitizeHtml(WebBrowseTemplate) %></a></td>The web browsing line worked in 2020.2.4 and looked like this: <td class="Property"><a href="<%=WebBrowseTemplate %>"><%=WebBrowseTemplate %></a></td>NodeDetails.ascx is located in this directory: C:\inetpub\SolarWinds\Orion\NetPerfMon\Resources\NodeDetails\
This is indeed a result of HTML sanitization. We are tracking this under CORE-17460.
Has the been resolved in the 2020.2.6 release? I don't recall seeing it in the release notes.
Thanks for confirmation Tony. this week we are going to upgrade the 2020.2.6 version.did you find out the any new Feature. As per release notes below new one available. New user interface for custom properties management.
