Does anyone at SolarWinds have news or information about this new zero day attack report that just came out the other day?????
@alansmith, here is what SolarWinds has published
And here it is on THWACK: https://thwack.solarwinds.com/product-forums/serv-u-ftp-mft/b/news/posts/patch-available-for-serv-u-memory-escape-vulnerability
For more information, please see our Trust Center.
perfect thank you
