Hi TEam,
We have below platform/ environment
As per below link I know best practice to reboot orion server
https://support.solarwinds.com/SuccessCenter/s/article/Orion-server-reboot-Best-practices?language=en_US
now I want to know the sequence/ best practices of stop orion services.
Can someone help me on this.
Yup, if that is what you are looking for then you are correct, in older versions we use to follow the same procedure.
Stop services on APE's and AWS and finally stop the services on Main poller.
In your case
1. stop APE/AWS services
2. Then stop HA
3. Then stop services on Main poller
And if you want to start the services then it would be:
1. Start services on Main poller
2. Start services on HA Server
3. Enable HA
4. Start services on APE
5. Start services on AWS
I feel like Orion is pretty robust about not being too worried about specific services. I've killed services 100 different ways over the years, the main trick being that if you have HA you need to disable that first to avoid having it try to bounce you over to the backup server.
True, want to know sequence that is first do i need to stop services from APE, AWS, HA and last Main poller then as per recomendation needs to reboot server, isn't it?
Cool, thanks for sharing thought and experience.
Just added start sequence as well, hope it helps.
good, thanks for help
