Hi
iam unable to download config by NCM of Cisco ASA 5545
error:
Connectivity issues, discarding configuration (or configuration is too short)
@makecrazy, if you enable session tracing per this article what do the session trace logs say?
[33bf2722] [06/10/2021 18:34:14.518] -----------------Net. SWTelnet v7.12.4.922------------------- [33bf2722] [06/10/2021 18:34:14.565] UseCustomMorePromptBehaviour: False [33bf2722] [06/10/2021 18:34:14.830] MorePromptKey: [33bf2722] [06/10/2021 18:34:14.940] Custom MorePrompt Pattern: [33bf2722] [06/10/2021 18:34:15.018] Login Attempts: 1 [33bf2722] [06/10/2021 18:34:15.065] UseKeyboardInteractiveAuthentication: False [33bf2722] [06/10/2021 18:34:15.127] Enable Identifier: #$ [33bf2722] [06/10/2021 18:34:15.174] Device Template: *** cisco asa *** Connection Profile: cisco asa [33bf2722] [06/10/2021 18:34:15.221] UseExactPromptMatch=False [33bf2722] [06/10/2021 18:34:15.283] Menu-based mode=False [33bf2722] [06/10/2021 18:34:15.315] FreezeLoginForPreCommands mode= False [33bf2722] [06/10/2021 18:34:15.440] CommandCharKey = Default [33bf2722] [06/10/2021 18:34:15.487] FISP mode= False [33bf2722] [06/10/2021 18:34:15.533] UseVirtualPromptForCommands False [33bf2722] [06/10/2021 18:34:15.565] VirtualPrompt: > [33bf2722] [06/10/2021 18:34:15.596] VirtualEnablePrompt: # [33bf2722] [06/10/2021 18:34:15.627] Responce Timeout in seconds: 15 [33bf2722] [06/10/2021 18:34:15.658] Connection Timeout in seconds: 45 [33bf2722] [06/10/2021 18:34:15.674] Resx Culture is: English (United States) [33bf2722] [06/10/2021 18:34:15.705] Encoding: Unicode (UTF-8) [33bf2722] [06/10/2021 18:34:15.721] Process Architecture : 64-bit [33bf2722] [06/10/2021 18:34:15.752] WOD details: EncryptionAlgorithm: Auto WODSSH Version: 2.8.0.196 WODSSH Assembly Version: 2.8.0.196 WODSSH Assembly location: \Program Files (x86)\SolarWinds\Orion\WeOnlyDo\WeOnlyDo.Client.SSH.dll AllocatePty: True Authentication: Password DebugFile: C:\ProgramData\SolarWinds\Logs\Orion\CLI\Session-Trace\NCM\10.95.0.173-SWTelnetDebug[0].txt EncryptionList: aes128-ctr,aes128-cbc,3des-cbc,blowfish-cbc,aes192-ctr,aes192-cbc,aes256-ctr,aes256-cbc,chacha20-poly1305@openssh.com,rijndael-cbc@lysator.liu.se ExitSignal: FingerPrintType: MD5 FIPS: False ForwardHost: ForwardPort: 0 HMacList: hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-sha1-96 Hostname: 10.95.0.173 KeepAlives: 0 KeyExchangeList: diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ext-info-c KeyFowarding: False Login: solarwind Port: 22 Protocol: SSHAuto ProxyHostname: ProxyLogin: ProxyPort: 1080 ProxyType: ProxyNone RemoteIdentification: ShowStdErrorMessages: True StripANSI: True Subsystem: TerminalType: vt100 Timeout: 45 [33bf2722] [06/10/2021 18:34:16.127] StateChange: Connecting [33bf2722] [06/10/2021 18:34:16.815] Got HostFingerPrint: System.Byte[] [33bf2722] [06/10/2021 18:34:16.940] SWTelnet9 Crypto Information Begin [33bf2722] [06/10/2021 18:34:16.971] Protocol = SSH2 [33bf2722] [06/10/2021 18:34:17.018] RemoteName = 10.95.0.173 [33bf2722] [06/10/2021 18:34:17.033] SCcipher = AES128ctr [33bf2722] [06/10/2021 18:34:17.080] CSCipher = AES128ctr [33bf2722] [06/10/2021 18:34:17.127] Keys = ssh-rsa [33bf2722] [06/10/2021 18:34:17.190] SWTelnet9 Crypto Information End [33bf2722] [06/10/2021 18:34:18.362] TimerTick: mstrData=<> State=Connecting [33bf2722] [06/10/2021 18:34:18.377] Pending Disconnect = False [33bf2722] [06/10/2021 18:34:18.424] StateChange: Connected [33bf2722] [06/10/2021 18:34:18.471] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any... [33bf2722] [06/10/2021 18:34:18.518] Connected! [33bf2722] [06/10/2021 18:34:18.580] Sending something to get a banner [33bf2722] [06/10/2021 18:34:18.627] <-- [33bf2722] [06/10/2021 18:34:19.581] ==>ACCESS IS RESTRICTED TO HBL AUTHORIZED PERSONNEL ONLY!!This is a privately owned computing system.Access is permitted only by authorized employees or agents of the company.The system may be used only for authorized company business.Company management approval is required for all access privileges.This system is equipped with a security system intended to prevent andThis system is equipped with a security system intended to prevent andrecord unauthorized access attempts.Unauthorized access or use is a crime under the law.Type help or '' for a list of available commands.ACCESS IS RESTRICTED TO HBL AUTHORIZED PERSONNEL ONLY!!ACCESS IS RESTRICTED TO HBL AUTHORIZED PERSONNEL ONLY!! This is a privately owned computing system.ACCESS IS RESTRICTED TO HBL AUTHORIZED PERSONNEL ONLY!!This is a privately owned computing system.The system may be used only for authorized company business.Unauthorized access or use is a crime under the law.User solarwind logged in to HOK-EXT-VPN-1Logins over the last 91 days: 191. Last login: 18:34:26 PKT Jun 10 2021 from 10.200.51.3Failed logins since the last login: 0. Last failed login: 17:12:17 PKT Jun 10 2021 from 10.200.51.3Type help or '?' for a list of available commands. HOK-EXT-VPN-1/pri/stby> - Received data when busy. Put it into buffer for later process. CurrentBuffer='ACCESS IS RESTRICTED TO HBL AUTHORIZED PERSONNEL ONLY!!This is a privately owned computing system.Access is permitted only by authorized employees or agents of the company.The system may be used only for authorized company business.Company management approval is required for all access privileges.This system is equipped with a security system intended to prevent andThis system is equipped with a security system intended to prevent andrecord unauthorized access attempts.Unauthorized access or use is a crime under the law.Type help or '' for a list of available commands.ACCESS IS RESTRICTED TO HBL AUTHORIZED PERSONNEL ONLY!!ACCESS IS RESTRICTED TO HBL AUTHORIZED PERSONNEL ONLY!! This is a privately owned computing system.ACCESS IS RESTRICTED TO HBL AUTHORIZED PERSONNEL ONLY!!This is a privately owned computing system.The system may be used only for authorized company business.Unauthorized access or use is a crime under the law.User solarwind logged in to HOK-EXT-VPN-1Logins over the last 91 days: 191. Last login: 18:34:26 PKT Jun 10 2021 from 10.200.51.3Failed logins since the last login: 0. Last failed login: 17:12:17 PKT Jun 10 2021 from 10.200.51.3Type help or '?' for a list of available commands. HOK-EXT-VPN-1/pri/stby> ' [33bf2722] [06/10/2021 18:34:19.690] -->ACCESS IS RESTRICTED TO HBL AUTHORIZED PERSONNEL ONLY!!This is a privately owned computing system.Access is permitted only by authorized employees or agents of the company.The system may be used only for authorized company business.Company management approval is required for all access privileges.This system is equipped with a security system intended to prevent andThis system is equipped with a security system intended to prevent andrecord unauthorized access attempts.Unauthorized access or use is a crime under the law.Type help or '' for a list of available commands.ACCESS IS RESTRICTED TO HBL AUTHORIZED PERSONNEL ONLY!! [33bf2722] [06/10/2021 18:34:19.705] -->ACCESS IS RESTRICTED TO HBL AUTHORIZED PERSONNEL ONLY!! [33bf2722] [06/10/2021 18:34:19.721] -->This is a privately owned computing system. [33bf2722] [06/10/2021 18:34:19.752] -->ACCESS IS RESTRICTED TO HBL AUTHORIZED PERSONNEL ONLY!! [33bf2722] [06/10/2021 18:34:19.783] -->This is a privately owned computing system. [33bf2722] [06/10/2021 18:34:19.815] -->The system may be used only for authorized company business. [33bf2722] [06/10/2021 18:34:19.846] -->Unauthorized access or use is a crime under the law. [33bf2722] [06/10/2021 18:34:19.862] -->User solarwind logged in to HOK-EXT-VPN-1 [33bf2722] [06/10/2021 18:34:19.893] -->Logins over the last 91 days: 191. Last login: 18:34:26 PKT Jun 10 2021 from 10.200.51.3 [33bf2722] [06/10/2021 18:34:19.924] -->Failed logins since the last login: 0. Last failed login: 17:12:17 PKT Jun 10 2021 from 10.200.51.3 [33bf2722] [06/10/2021 18:34:19.955] -->Type help or '?' for a list of available commands. [33bf2722] [06/10/2021 18:34:19.987] --> [33bf2722] [06/10/2021 18:34:20.018] -->HOK-EXT-VPN-1/pri/stby> [33bf2722] [06/10/2021 18:34:20.049] --> [33bf2722] [06/10/2021 18:34:20.080] ProcessLogin State: Banner [33bf2722] [06/10/2021 18:34:20.112] no credentials needed - Command mode prompt detected [33bf2722] [06/10/2021 18:34:20.158] Prompt being set to: HOK-EXT-VPN-1/pri/stby> [33bf2722] [06/10/2021 18:34:20.190] Logged into device [33bf2722] [06/10/2021 18:34:20.221] <-- [33bf2722] [06/10/2021 18:34:20.393] --> [33bf2722] [06/10/2021 18:34:20.408] -->HOK-EXT-VPN-1/pri/stby> [33bf2722] [06/10/2021 18:34:20.440] Start check prompt for menu-based device [33bf2722] [06/10/2021 18:34:20.487] Process line = <> [33bf2722] [06/10/2021 18:34:20.533] Process line = <HOK-EXT-VPN-1/pri/stby> > [33bf2722] [06/10/2021 18:34:20.658] SendNextCommand Running: terminal pager 0 [33bf2722] [06/10/2021 18:34:20.705] <-- terminal pager 0 [33bf2722] [06/10/2021 18:34:20.830] --> [33bf2722] [06/10/2021 18:34:20.846] --> [33bf2722] [06/10/2021 18:34:20.877] -->HOK-EXT-VPN-1/pri/stby> [33bf2722] [06/10/2021 18:34:20.908] Incomplete buffer with prompt is detected - save all lines to echo buffer [33bf2722] [06/10/2021 18:34:20.924] Echo not detected yet. Push back data to echo buffer, EchoBuffer = <<< HOK-EXT-VPN-1/pri/stby> >>> [33bf2722] [06/10/2021 18:34:20.955] Start detecting command echo in echo buffer... [33bf2722] [06/10/2021 18:34:20.987] Start check prompt for menu-based device [33bf2722] [06/10/2021 18:34:21.018] Process line = <> [33bf2722] [06/10/2021 18:34:21.049] Process line = <> [33bf2722] [06/10/2021 18:34:21.065] Process line = <HOK-EXT-VPN-1/pri/stby> > [33bf2722] [06/10/2021 18:34:21.112] Waiting for the Current Command (terminal pager 0) to be Echoed [33bf2722] [06/10/2021 18:34:21.330] -->terminal pager 0 [33bf2722] [06/10/2021 18:34:21.346] --> ^ [33bf2722] [06/10/2021 18:34:21.377] -->ERROR: % Invalid input detected at '^' marker. [33bf2722] [06/10/2021 18:34:21.393] --> [33bf2722] [06/10/2021 18:34:21.440] -->HOK-EXT-VPN-1/pri/stby> [33bf2722] [06/10/2021 18:34:21.455] Incomplete buffer with prompt is detected - save all lines to echo buffer [33bf2722] [06/10/2021 18:34:21.487] Echo not detected yet. Push back data to echo buffer, EchoBuffer = <<< HOK-EXT-VPN-1/pri/stby> terminal pager 0 ^ ERROR: % Invalid input detected at '^' marker. HOK-EXT-VPN-1/pri/stby> >>> [33bf2722] [06/10/2021 18:34:21.549] Start detecting command echo in echo buffer... [33bf2722] [06/10/2021 18:34:21.565] Echo is detected, EchoBuffer = <<< HOK-EXT-VPN-1/pri/stby> terminal pager 0 ^ ERROR: % Invalid input detected at '^' marker. HOK-EXT-VPN-1/pri/stby> >>> [33bf2722] [06/10/2021 18:34:21.612] Remove Prompt - detected prompt line via RegEx [33bf2722] [06/10/2021 18:34:21.627] Remove Prompt - prompt line is on invalid place, Save It. data= HOK-EXT-VPN-1/pri/stby> terminal pager 0 ^ ERROR: % Invalid input detected at '^' marker. HOK-EXT-VPN-1/pri/stby> FoundPromptLine=HOK-EXT-VPN-1/pri/stby> [33bf2722] [06/10/2021 18:34:21.674] Prompt removed at line: HOK-EXT-VPN-1/pri/stby> [33bf2722] [06/10/2021 18:34:21.705] Echo and prompt are removed if they exist, out buffer = <<< ^ ERROR: % Invalid input detected at '^' marker. HOK-EXT-VPN-1/pri/stby> >>> [33bf2722] [06/10/2021 18:34:21.737] Start check prompt for menu-based device [33bf2722] [06/10/2021 18:34:21.768] Process line = <> [33bf2722] [06/10/2021 18:34:21.799] Process line = <> [33bf2722] [06/10/2021 18:34:21.830] Process line = <^> [33bf2722] [06/10/2021 18:34:21.862] Fuzzy match detector start detecting prompt. String1=^ String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:21.893] Save Command output: ^ [33bf2722] [06/10/2021 18:34:21.924] Process line = <ERROR: % Invalid input detected at '^' marker.> [33bf2722] [06/10/2021 18:34:21.955] Fuzzy match detector start detecting prompt. String1=error:%invalidinputdetectedat'^'marker. String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:21.987] Save Command output: ERROR: % Invalid input detected at '^' marker. [33bf2722] [06/10/2021 18:34:22.018] Process line = <> [33bf2722] [06/10/2021 18:34:22.049] Process line = <HOK-EXT-VPN-1/pri/stby> > [33bf2722] [06/10/2021 18:34:22.080] SendNextCommand Running: show version [33bf2722] [06/10/2021 18:34:22.096] <-- show version [33bf2722] [06/10/2021 18:34:22.143] Process line = <> [33bf2722] [06/10/2021 18:34:22.221] -->show version [33bf2722] [06/10/2021 18:34:22.237] --> [33bf2722] [06/10/2021 18:34:22.268] Complete buffer is detected - save all lines to the echo buffer [33bf2722] [06/10/2021 18:34:22.299] Echo not detected yet. Push back data to echo buffer, EchoBuffer = <<<show version >>> [33bf2722] [06/10/2021 18:34:22.315] Start detecting command echo in echo buffer... [33bf2722] [06/10/2021 18:34:22.346] Echo is detected, EchoBuffer = <<<show version >>> [33bf2722] [06/10/2021 18:34:22.377] RemovePrompt = prompt not found via Regex [33bf2722] [06/10/2021 18:34:22.424] Echo and prompt are removed if they exist, out buffer = <<<>>> [33bf2722] [06/10/2021 18:34:22.455] Start check prompt for menu-based device [33bf2722] [06/10/2021 18:34:22.487] Process line = <> [33bf2722] [06/10/2021 18:34:23.252] --> [33bf2722] [06/10/2021 18:34:23.268] -->Cisco Adaptive Security Appliance Software Version 9.12(3)12 [33bf2722] [06/10/2021 18:34:23.283] -->SSP Operating System Version 2.6(1.198) [33bf2722] [06/10/2021 18:34:23.315] -->Device Manager Version 7.12(2) [33bf2722] [06/10/2021 18:34:23.409] --> [33bf2722] [06/10/2021 18:34:23.440] -->Compiled on Fri 17-Apr-20 10:50 PDT by builders [33bf2722] [06/10/2021 18:34:23.472] -->System image file is "disk0:/asa9-12-3-12-smp-k8.bin" [33bf2722] [06/10/2021 18:34:23.502] -->Config file at boot was "startup-config" [33bf2722] [06/10/2021 18:34:23.533] --> [33bf2722] [06/10/2021 18:34:23.549] -->HOK-EXT-VPN-1 up 270 days 20 hours [33bf2722] [06/10/2021 18:34:23.627] -->failover cluster up 7 years 361 days [33bf2722] [06/10/2021 18:34:23.659] --> [33bf2722] [06/10/2021 18:34:23.705] -->Hardware: ASA5545, 12288 MB RAM, CPU Lynnfield 2660 MHz, 1 CPU (8 cores) [33bf2722] [06/10/2021 18:34:23.737] --> ASA: 6487 MB RAM, 1 CPU (1 core) [33bf2722] [06/10/2021 18:34:23.768] -->Internal ATA Compact Flash, 8192MB [33bf2722] [06/10/2021 18:34:23.799] -->BIOS Flash MX25L6445E @ 0xffbb0000, 8192KB [33bf2722] [06/10/2021 18:34:23.830] --> [33bf2722] [06/10/2021 18:34:23.878] -->Encryption hardware device : Cisco ASA Crypto on-board accelerator (revision 0x1) [33bf2722] [06/10/2021 18:34:23.908] --> Boot microcode : CNPx-MC-BOOT-2.00 [33bf2722] [06/10/2021 18:34:23.940] --> SSL/IKE microcode : CNPx-MC-SSL-SB-PLUS-0005 [33bf2722] [06/10/2021 18:34:23.971] --> IPSec microcode : CNPx-MC-IPSEC-MAIN-0026 [33bf2722] [06/10/2021 18:34:24.002] --> Number of accelerators: 1 [33bf2722] [06/10/2021 18:34:24.034] -->Baseboard Management Controller (revision 0x1) Firmware Version: 2.4 [33bf2722] [06/10/2021 18:34:24.065] --> [33bf2722] [06/10/2021 18:34:24.096] --> [33bf2722] [06/10/2021 18:34:24.127] --><--- More ---> [33bf2722] [06/10/2021 18:34:24.158] Start check prompt for menu-based device [33bf2722] [06/10/2021 18:34:24.190] Process line = <> [33bf2722] [06/10/2021 18:34:24.221] Process line = <Cisco Adaptive Security Appliance Software Version 9.12(3)12 > [33bf2722] [06/10/2021 18:34:24.283] Fuzzy match detector start detecting prompt. String1=ciscoadaptivesecurityappliancesoftwareversion9.12(3)12 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:24.315] Removed data in (...) Output= ciscoadaptivesecurityappliancesoftwareversion9.1212 [33bf2722] [06/10/2021 18:34:24.362] Save Command output: Cisco Adaptive Security Appliance Software Version 9.12(3)12 [33bf2722] [06/10/2021 18:34:24.393] Process line = <SSP Operating System Version 2.6(1.198)> [33bf2722] [06/10/2021 18:34:24.440] Fuzzy match detector start detecting prompt. String1=sspoperatingsystemversion2.6(1.198) String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:24.518] Removed data in (...) Output= sspoperatingsystemversion2.6 [33bf2722] [06/10/2021 18:34:24.580] Save Command output: SSP Operating System Version 2.6(1.198) [33bf2722] [06/10/2021 18:34:24.627] Process line = <Device Manager Version 7.12(2)> [33bf2722] [06/10/2021 18:34:24.659] Fuzzy match detector start detecting prompt. String1=devicemanagerversion7.12(2) String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:24.690] Removed data in (...) Output= devicemanagerversion7.12 [33bf2722] [06/10/2021 18:34:24.737] Save Command output: Device Manager Version 7.12(2) [33bf2722] [06/10/2021 18:34:24.784] Process line = <> [33bf2722] [06/10/2021 18:34:24.815] Process line = <Compiled on Fri 17-Apr-20 10:50 PDT by builders> [33bf2722] [06/10/2021 18:34:24.846] Fuzzy match detector start detecting prompt. String1=compiledonfri17-apr-2010:50pdtbybuilders String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:25.471] Save Command output: Compiled on Fri 17-Apr-20 10:50 PDT by builders [33bf2722] [06/10/2021 18:34:25.572] Process line = <System image file is "disk0:/asa9-12-3-12-smp-k8.bin"> [33bf2722] [06/10/2021 18:34:25.612] Fuzzy match detector start detecting prompt. String1=systemimagefileis"disk0:/asa9-12-3-12-smp-k8.bin" String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:25.659] Save Command output: System image file is "disk0:/asa9-12-3-12-smp-k8.bin" [33bf2722] [06/10/2021 18:34:25.705] Process line = <Config file at boot was "startup-config"> [33bf2722] [06/10/2021 18:34:25.737] Fuzzy match detector start detecting prompt. String1=configfileatbootwas"startup-config" String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:25.768] Save Command output: Config file at boot was "startup-config" [33bf2722] [06/10/2021 18:34:25.799] Process line = <> [33bf2722] [06/10/2021 18:34:25.846] Process line = <HOK-EXT-VPN-1 up 270 days 20 hours> [33bf2722] [06/10/2021 18:34:25.877] Fuzzy match detector start detecting prompt. String1=hok-ext-vpn-1up270days20hours String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:25.909] Save Command output: HOK-EXT-VPN-1 up 270 days 20 hours [33bf2722] [06/10/2021 18:34:25.924] Process line = <failover cluster up 7 years 361 days> [33bf2722] [06/10/2021 18:34:25.955] Fuzzy match detector start detecting prompt. String1=failoverclusterup7years361days String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:26.003] Save Command output: failover cluster up 7 years 361 days [33bf2722] [06/10/2021 18:34:26.049] Process line = <> [33bf2722] [06/10/2021 18:34:26.080] Process line = <Hardware: ASA5545, 12288 MB RAM, CPU Lynnfield 2660 MHz, 1 CPU (8 cores)> [33bf2722] [06/10/2021 18:34:26.112] Fuzzy match detector start detecting prompt. String1=hardware:asa5545,12288mbram,cpulynnfield2660mhz,1cpu(8cores) String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:26.143] Removed data in (...) Output= hardware:asa5545,12288mbram,cpulynnfield2660mhz,1cpu [33bf2722] [06/10/2021 18:34:26.174] Save Command output: Hardware: ASA5545, 12288 MB RAM, CPU Lynnfield 2660 MHz, 1 CPU (8 cores) [33bf2722] [06/10/2021 18:34:26.205] Process line = < ASA: 6487 MB RAM, 1 CPU (1 core)> [33bf2722] [06/10/2021 18:34:26.237] Fuzzy match detector start detecting prompt. String1=asa:6487mbram,1cpu(1core) String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:26.268] Removed data in (...) Output= asa:6487mbram,1cpu [33bf2722] [06/10/2021 18:34:26.299] Save Command output: ASA: 6487 MB RAM, 1 CPU (1 core) [33bf2722] [06/10/2021 18:34:26.346] Process line = <Internal ATA Compact Flash, 8192MB> [33bf2722] [06/10/2021 18:34:26.377] Fuzzy match detector start detecting prompt. String1=internalatacompactflash,8192mb String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:26.393] Save Command output: Internal ATA Compact Flash, 8192MB [33bf2722] [06/10/2021 18:34:26.440] Process line = <BIOS Flash MX25L6445E @ 0xffbb0000, 8192KB> [33bf2722] [06/10/2021 18:34:26.487] Fuzzy match detector start detecting prompt. String1=biosflashmx25l6445e@0xffbb0000,8192kb String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:26.518] Save Command output: BIOS Flash MX25L6445E @ 0xffbb0000, 8192KB [33bf2722] [06/10/2021 18:34:26.565] Process line = <> [33bf2722] [06/10/2021 18:34:26.612] Process line = <Encryption hardware device : Cisco ASA Crypto on-board accelerator (revision 0x1)> [33bf2722] [06/10/2021 18:34:26.659] Fuzzy match detector start detecting prompt. String1=encryptionhardwaredevice:ciscoasacryptoon-boardaccelerator(revision0x1) String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:26.721] Removed data in (...) Output= encryptionhardwaredevice:ciscoasacryptoon-boardaccelerator [33bf2722] [06/10/2021 18:34:26.752] Save Command output: Encryption hardware device : Cisco ASA Crypto on-board accelerator (revision 0x1) [33bf2722] [06/10/2021 18:34:26.784] Process line = < Boot microcode : CNPx-MC-BOOT-2.00> [33bf2722] [06/10/2021 18:34:26.815] Fuzzy match detector start detecting prompt. String1=bootmicrocode:cnpx-mc-boot-2.00 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:26.846] Save Command output: Boot microcode : CNPx-MC-BOOT-2.00 [33bf2722] [06/10/2021 18:34:26.877] Process line = < SSL/IKE microcode : CNPx-MC-SSL-SB-PLUS-0005> [33bf2722] [06/10/2021 18:34:26.909] Fuzzy match detector start detecting prompt. String1=ssl/ikemicrocode:cnpx-mc-ssl-sb-plus-0005 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:26.955] Save Command output: SSL/IKE microcode : CNPx-MC-SSL-SB-PLUS-0005 [33bf2722] [06/10/2021 18:34:26.987] Process line = < IPSec microcode : CNPx-MC-IPSEC-MAIN-0026> [33bf2722] [06/10/2021 18:34:27.112] Fuzzy match detector start detecting prompt. String1=ipsecmicrocode:cnpx-mc-ipsec-main-0026 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:27.159] Save Command output: IPSec microcode : CNPx-MC-IPSEC-MAIN-0026 [33bf2722] [06/10/2021 18:34:27.190] Process line = < Number of accelerators: 1> [33bf2722] [06/10/2021 18:34:27.221] Fuzzy match detector start detecting prompt. String1=numberofaccelerators:1 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:27.268] Save Command output: Number of accelerators: 1 [33bf2722] [06/10/2021 18:34:27.299] Process line = <Baseboard Management Controller (revision 0x1) Firmware Version: 2.4> [33bf2722] [06/10/2021 18:34:27.330] Fuzzy match detector start detecting prompt. String1=baseboardmanagementcontroller(revision0x1)firmwareversion:2.4 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:27.362] Removed data in (...) Output= baseboardmanagementcontrollerfirmwareversion:2.4 [33bf2722] [06/10/2021 18:34:27.393] Save Command output: Baseboard Management Controller (revision 0x1) Firmware Version: 2.4 [33bf2722] [06/10/2021 18:34:27.424] Process line = <> [33bf2722] [06/10/2021 18:34:27.455] Process line = <> [33bf2722] [06/10/2021 18:34:27.487] Process line = <<--- More --->> [33bf2722] [06/10/2021 18:34:27.518] Fuzzy match detector start detecting prompt. String1=<---more---> String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:27.566] Send GotAMore request to timer... LastData: <--- More ---> PushBackBuffer: [33bf2722] [06/10/2021 18:34:27.862] TimerTick: mstrData=<<--- More --->> State=Connected [33bf2722] [06/10/2021 18:34:28.377] Pending Disconnect = False [33bf2722] [06/10/2021 18:34:28.627] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any... [33bf2722] [06/10/2021 18:34:28.674] Timer Send GotAMore LastData: <--- More ---> PushBackBuffer: <--- More ---> [33bf2722] [06/10/2021 18:34:28.737] <-- [33bf2722] [06/10/2021 18:34:28.799] Timer send GotAMore: clear lastdata ands last GoodLine [33bf2722] [06/10/2021 18:34:28.830] Fuzzy match detector start detecting prompt. String1= String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:28.909] --> [33bf2722] [06/10/2021 18:34:28.924] --> [33bf2722] [06/10/2021 18:34:28.955] --> 0: Int: Internal-Data0/0 : address is 6c41.6a1e.8d96, irq 11 [33bf2722] [06/10/2021 18:34:28.987] --> [33bf2722] [06/10/2021 18:34:29.018] Start check prompt for menu-based device [33bf2722] [06/10/2021 18:34:29.049] Process line = <> [33bf2722] [06/10/2021 18:34:29.065] Process line = < > [33bf2722] [06/10/2021 18:34:29.112] Fuzzy match detector start detecting prompt. String1= String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:29.143] Save Command output: [33bf2722] [06/10/2021 18:34:29.174] Process line = < 0: Int: Internal-Data0/0 : address is 6c41.6a1e.8d96, irq 11> [33bf2722] [06/10/2021 18:34:29.205] Fuzzy match detector start detecting prompt. String1=0:int:internal-data0/0:addressis6c41.6a1e.8d96,irq11 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:29.237] Save Command output: 0: Int: Internal-Data0/0 : address is 6c41.6a1e.8d96, irq 11 [33bf2722] [06/10/2021 18:34:29.268] Process line = <> [33bf2722] [06/10/2021 18:34:30.018] --> 1: Ext: GigabitEthernet0/0 : address is 6c41.6a1e.8d9b, irq 5 [33bf2722] [06/10/2021 18:34:30.049] --> 2: Ext: GigabitEthernet0/1 : address is 6c41.6a1e.8d97, irq 5 [33bf2722] [06/10/2021 18:34:30.081] --> 3: Ext: GigabitEthernet0/2 : address is 6c41.6a1e.8d9c, irq 10 [33bf2722] [06/10/2021 18:34:30.112] --> 4: Ext: GigabitEthernet0/3 : address is 6c41.6a1e.8d98, irq 10 [33bf2722] [06/10/2021 18:34:30.190] --> 5: Ext: GigabitEthernet0/4 : address is 6c41.6a1e.8d9d, irq 5 [33bf2722] [06/10/2021 18:34:30.221] --> 6: Ext: GigabitEthernet0/5 : address is 6c41.6a1e.8d99, irq 5 [33bf2722] [06/10/2021 18:34:30.252] --> 7: Ext: GigabitEthernet0/6 : address is 6c41.6a1e.8d9e, irq 10 [33bf2722] [06/10/2021 18:34:30.284] --> 8: Ext: GigabitEthernet0/7 : address is 6c41.6a1e.8d9a, irq 10 [33bf2722] [06/10/2021 18:34:30.315] --> 9: Int: Internal-Data0/1 : address is 0000.0001.0002, irq 0 [33bf2722] [06/10/2021 18:34:30.362] -->10: Int: Internal-Control0/0 : address is 0000.0001.0001, irq 0 [33bf2722] [06/10/2021 18:34:30.393] -->11: Int: Internal-Data0/2 : address is 0000.0001.0003, irq 0 [33bf2722] [06/10/2021 18:34:30.424] -->12: Ext: Management0/0 : address is 6c41.6a1e.8d96, irq 0 [33bf2722] [06/10/2021 18:34:31.174] -->13: Int: Internal-Data0/3 : address is 0000.0100.0001, irq 0 [33bf2722] [06/10/2021 18:34:31.346] --> [33bf2722] [06/10/2021 18:34:31.612] -->Licensed features for this platform: [33bf2722] [06/10/2021 18:34:31.674] -->Maximum Physical Interfaces : Unlimited perpetual [33bf2722] [06/10/2021 18:34:31.706] -->Maximum VLANs : 300 perpetual [33bf2722] [06/10/2021 18:34:31.737] -->Inside Hosts : Unlimited perpetual [33bf2722] [06/10/2021 18:34:31.784] -->Failover : Active/Active perpetual [33bf2722] [06/10/2021 18:34:31.831] -->Encryption-DES : Enabled perpetual [33bf2722] [06/10/2021 18:34:31.862] -->Encryption-3DES-AES : Enabled perpetual [33bf2722] [06/10/2021 18:34:31.893] -->Security Contexts : 2 perpetual [33bf2722] [06/10/2021 18:34:31.924] -->Carrier : Disabled perpetual [33bf2722] [06/10/2021 18:34:31.971] --><--- More ---> [33bf2722] [06/10/2021 18:34:32.002] Start check prompt for menu-based device [33bf2722] [06/10/2021 18:34:32.065] Process line = < 1: Ext: GigabitEthernet0/0 : address is 6c41.6a1e.8d9b, irq 5> [33bf2722] [06/10/2021 18:34:32.127] Fuzzy match detector start detecting prompt. String1=1:ext:gigabitethernet0/0:addressis6c41.6a1e.8d9b,irq5 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:32.159] Save Command output: 1: Ext: GigabitEthernet0/0 : address is 6c41.6a1e.8d9b, irq 5 [33bf2722] [06/10/2021 18:34:32.206] Process line = < 2: Ext: GigabitEthernet0/1 : address is 6c41.6a1e.8d97, irq 5> [33bf2722] [06/10/2021 18:34:32.237] Fuzzy match detector start detecting prompt. String1=2:ext:gigabitethernet0/1:addressis6c41.6a1e.8d97,irq5 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:32.268] Save Command output: 2: Ext: GigabitEthernet0/1 : address is 6c41.6a1e.8d97, irq 5 [33bf2722] [06/10/2021 18:34:32.284] Process line = < 3: Ext: GigabitEthernet0/2 : address is 6c41.6a1e.8d9c, irq 10> [33bf2722] [06/10/2021 18:34:32.315] Fuzzy match detector start detecting prompt. String1=3:ext:gigabitethernet0/2:addressis6c41.6a1e.8d9c,irq10 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:32.346] Save Command output: 3: Ext: GigabitEthernet0/2 : address is 6c41.6a1e.8d9c, irq 10 [33bf2722] [06/10/2021 18:34:32.377] Process line = < 4: Ext: GigabitEthernet0/3 : address is 6c41.6a1e.8d98, irq 10> [33bf2722] [06/10/2021 18:34:32.409] Fuzzy match detector start detecting prompt. String1=4:ext:gigabitethernet0/3:addressis6c41.6a1e.8d98,irq10 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:32.440] Save Command output: 4: Ext: GigabitEthernet0/3 : address is 6c41.6a1e.8d98, irq 10 [33bf2722] [06/10/2021 18:34:32.471] Process line = < 5: Ext: GigabitEthernet0/4 : address is 6c41.6a1e.8d9d, irq 5> [33bf2722] [06/10/2021 18:34:32.502] Fuzzy match detector start detecting prompt. String1=5:ext:gigabitethernet0/4:addressis6c41.6a1e.8d9d,irq5 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:32.549] Save Command output: 5: Ext: GigabitEthernet0/4 : address is 6c41.6a1e.8d9d, irq 5 [33bf2722] [06/10/2021 18:34:32.580] Process line = < 6: Ext: GigabitEthernet0/5 : address is 6c41.6a1e.8d99, irq 5> [33bf2722] [06/10/2021 18:34:32.596] Fuzzy match detector start detecting prompt. String1=6:ext:gigabitethernet0/5:addressis6c41.6a1e.8d99,irq5 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:32.643] Save Command output: 6: Ext: GigabitEthernet0/5 : address is 6c41.6a1e.8d99, irq 5 [33bf2722] [06/10/2021 18:34:32.674] Process line = < 7: Ext: GigabitEthernet0/6 : address is 6c41.6a1e.8d9e, irq 10> [33bf2722] [06/10/2021 18:34:32.705] Fuzzy match detector start detecting prompt. String1=7:ext:gigabitethernet0/6:addressis6c41.6a1e.8d9e,irq10 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:32.737] Save Command output: 7: Ext: GigabitEthernet0/6 : address is 6c41.6a1e.8d9e, irq 10 [33bf2722] [06/10/2021 18:34:32.768] Process line = < 8: Ext: GigabitEthernet0/7 : address is 6c41.6a1e.8d9a, irq 10> [33bf2722] [06/10/2021 18:34:32.799] Fuzzy match detector start detecting prompt. String1=8:ext:gigabitethernet0/7:addressis6c41.6a1e.8d9a,irq10 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:32.830] Save Command output: 8: Ext: GigabitEthernet0/7 : address is 6c41.6a1e.8d9a, irq 10 [33bf2722] [06/10/2021 18:34:32.862] Process line = < 9: Int: Internal-Data0/1 : address is 0000.0001.0002, irq 0> [33bf2722] [06/10/2021 18:34:32.893] Fuzzy match detector start detecting prompt. String1=9:int:internal-data0/1:addressis0000.0001.0002,irq0 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:32.924] Save Command output: 9: Int: Internal-Data0/1 : address is 0000.0001.0002, irq 0 [33bf2722] [06/10/2021 18:34:32.955] Process line = <10: Int: Internal-Control0/0 : address is 0000.0001.0001, irq 0> [33bf2722] [06/10/2021 18:34:33.049] Fuzzy match detector start detecting prompt. String1=10:int:internal-control0/0:addressis0000.0001.0001,irq0 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:33.096] Save Command output: 10: Int: Internal-Control0/0 : address is 0000.0001.0001, irq 0 [33bf2722] [06/10/2021 18:34:33.127] Process line = <11: Int: Internal-Data0/2 : address is 0000.0001.0003, irq 0> [33bf2722] [06/10/2021 18:34:33.159] Fuzzy match detector start detecting prompt. String1=11:int:internal-data0/2:addressis0000.0001.0003,irq0 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:33.190] Save Command output: 11: Int: Internal-Data0/2 : address is 0000.0001.0003, irq 0 [33bf2722] [06/10/2021 18:34:33.252] Process line = <12: Ext: Management0/0 : address is 6c41.6a1e.8d96, irq 0> [33bf2722] [06/10/2021 18:34:33.284] Fuzzy match detector start detecting prompt. String1=12:ext:management0/0:addressis6c41.6a1e.8d96,irq0 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:33.299] Save Command output: 12: Ext: Management0/0 : address is 6c41.6a1e.8d96, irq 0 [33bf2722] [06/10/2021 18:34:33.330] Process line = <13: Int: Internal-Data0/3 : address is 0000.0100.0001, irq 0> [33bf2722] [06/10/2021 18:34:33.362] Fuzzy match detector start detecting prompt. String1=13:int:internal-data0/3:addressis0000.0100.0001,irq0 String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:33.409] Save Command output: 13: Int: Internal-Data0/3 : address is 0000.0100.0001, irq 0 [33bf2722] [06/10/2021 18:34:33.440] Process line = <> [33bf2722] [06/10/2021 18:34:33.487] Process line = <Licensed features for this platform:> [33bf2722] [06/10/2021 18:34:34.127] Fuzzy match detector start detecting prompt. String1=licensedfeaturesforthisplatform: String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:34.299] Save Command output: Licensed features for this platform: [33bf2722] [06/10/2021 18:34:34.440] Process line = <Maximum Physical Interfaces : Unlimited perpetual> [33bf2722] [06/10/2021 18:34:34.549] Fuzzy match detector start detecting prompt. String1=maximumphysicalinterfaces:unlimitedperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:34.674] Save Command output: Maximum Physical Interfaces : Unlimited perpetual [33bf2722] [06/10/2021 18:34:34.705] Process line = <Maximum VLANs : 300 perpetual> [33bf2722] [06/10/2021 18:34:34.737] Fuzzy match detector start detecting prompt. String1=maximumvlans:300perpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:34.768] Save Command output: Maximum VLANs : 300 perpetual [33bf2722] [06/10/2021 18:34:34.799] Process line = <Inside Hosts : Unlimited perpetual> [33bf2722] [06/10/2021 18:34:34.831] Fuzzy match detector start detecting prompt. String1=insidehosts:unlimitedperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:34.862] Save Command output: Inside Hosts : Unlimited perpetual [33bf2722] [06/10/2021 18:34:34.893] Process line = <Failover : Active/Active perpetual> [33bf2722] [06/10/2021 18:34:34.924] Fuzzy match detector start detecting prompt. String1=failover:active/activeperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:34.955] Save Command output: Failover : Active/Active perpetual [33bf2722] [06/10/2021 18:34:34.987] Process line = <Encryption-DES : Enabled perpetual> [33bf2722] [06/10/2021 18:34:35.018] Fuzzy match detector start detecting prompt. String1=encryption-des:enabledperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:35.049] Save Command output: Encryption-DES : Enabled perpetual [33bf2722] [06/10/2021 18:34:35.080] Process line = <Encryption-3DES-AES : Enabled perpetual> [33bf2722] [06/10/2021 18:34:35.127] Fuzzy match detector start detecting prompt. String1=encryption-3des-aes:enabledperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:35.159] Save Command output: Encryption-3DES-AES : Enabled perpetual [33bf2722] [06/10/2021 18:34:35.205] Process line = <Security Contexts : 2 perpetual> [33bf2722] [06/10/2021 18:34:35.237] Fuzzy match detector start detecting prompt. String1=securitycontexts:2perpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:35.268] Save Command output: Security Contexts : 2 perpetual [33bf2722] [06/10/2021 18:34:35.299] Process line = <Carrier : Disabled perpetual> [33bf2722] [06/10/2021 18:34:35.330] Fuzzy match detector start detecting prompt. String1=carrier:disabledperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:35.362] Save Command output: Carrier : Disabled perpetual [33bf2722] [06/10/2021 18:34:35.393] Process line = <<--- More --->> [33bf2722] [06/10/2021 18:34:35.424] Fuzzy match detector start detecting prompt. String1=<---more---> String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:35.455] Send GotAMore request to timer... LastData: <--- More ---> PushBackBuffer: [33bf2722] [06/10/2021 18:34:37.377] TimerTick: mstrData=<<--- More --->> State=Connected [33bf2722] [06/10/2021 18:34:37.518] Pending Disconnect = False [33bf2722] [06/10/2021 18:34:37.596] Pre-Commands: Waiting more than 3 seconds for response start sending pre-command if any... [33bf2722] [06/10/2021 18:34:37.627] Timer Send GotAMore LastData: <--- More ---> PushBackBuffer: <--- More ---> [33bf2722] [06/10/2021 18:34:37.659] <-- [33bf2722] [06/10/2021 18:34:37.690] Timer send GotAMore: clear lastdata ands last GoodLine [33bf2722] [06/10/2021 18:34:37.721] Fuzzy match detector start detecting prompt. String1= String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:37.752] TimerTick: blankline - waited more than half response timeout - Sending Next Command [33bf2722] [06/10/2021 18:34:37.784] ==> AnyConnect Premium Peers : 2 perpetual - Received data when busy. Put it into buffer for later process. CurrentBuffer=' AnyConnect Premium Peers : 2 perpetual' [33bf2722] [06/10/2021 18:34:37.830] SendNextCommand Done: disconnecting [33bf2722] [06/10/2021 18:34:38.409] --> [33bf2722] [06/10/2021 18:34:38.424] --> [33bf2722] [06/10/2021 18:34:38.471] -->AnyConnect Premium Peers : 2 perpetual [33bf2722] [06/10/2021 18:34:38.518] -->AnyConnect Essentials : Disabled perpetual [33bf2722] [06/10/2021 18:34:38.565] -->Other VPN Peers : 2500 perpetual [33bf2722] [06/10/2021 18:34:38.612] -->Total VPN Peers : 2500 perpetual [33bf2722] [06/10/2021 18:34:38.643] -->AnyConnect for Mobile : Disabled perpetual [33bf2722] [06/10/2021 18:34:38.705] -->AnyConnect for Cisco VPN Phone : Disabled perpetual [33bf2722] [06/10/2021 18:34:38.752] -->Advanced Endpoint Assessment : Disabled perpetual [33bf2722] [06/10/2021 18:34:38.799] -->Shared License : Disabled perpetual [33bf2722] [06/10/2021 18:34:38.909] -->Total TLS Proxy Sessions : 2 perpetual [33bf2722] [06/10/2021 18:34:38.955] -->Botnet Traffic Filter : Disabled perpetual [33bf2722] [06/10/2021 18:34:38.987] -->IPS Module : Enabled perpetual [33bf2722] [06/10/2021 18:34:39.034] -->Cluster : Enabled perpetual [33bf2722] [06/10/2021 18:34:39.080] -->Cluster Members : 2 perpetual [33bf2722] [06/10/2021 18:34:39.112] --> [33bf2722] [06/10/2021 18:34:39.159] -->This platform has an ASA5545 VPN Premium license. [33bf2722] [06/10/2021 18:34:39.221] --> [33bf2722] [06/10/2021 18:34:39.268] --> [33bf2722] [06/10/2021 18:34:39.315] -->Failover cluster licensed features for this platform: [33bf2722] [06/10/2021 18:34:39.362] -->Maximum Physical Interfaces : Unlimited perpetual [33bf2722] [06/10/2021 18:34:39.409] -->Maximum VLANs : 300 perpetual [33bf2722] [06/10/2021 18:34:39.455] -->Inside Hosts : Unlimited perpetual [33bf2722] [06/10/2021 18:34:39.502] -->Failover : Active/Active perpetual [33bf2722] [06/10/2021 18:34:39.549] -->Encryption-DES : Enabled perpetual [33bf2722] [06/10/2021 18:34:39.596] -->Encryption-3DES-AES : Enabled perpetual [33bf2722] [06/10/2021 18:34:39.659] --><--- More ---> [33bf2722] [06/10/2021 18:34:39.706] Start check prompt for menu-based device [33bf2722] [06/10/2021 18:34:39.752] Process line = <> [33bf2722] [06/10/2021 18:34:39.799] Process line = < > [33bf2722] [06/10/2021 18:34:40.550] Fuzzy match detector start detecting prompt. String1= String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:40.612] Process line = <AnyConnect Premium Peers : 2 perpetual> [33bf2722] [06/10/2021 18:34:40.659] Fuzzy match detector start detecting prompt. String1=anyconnectpremiumpeers:2perpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:40.721] Process line = <AnyConnect Essentials : Disabled perpetual> [33bf2722] [06/10/2021 18:34:40.768] Fuzzy match detector start detecting prompt. String1=anyconnectessentials:disabledperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:40.815] Process line = <Other VPN Peers : 2500 perpetual> [33bf2722] [06/10/2021 18:34:40.862] Fuzzy match detector start detecting prompt. String1=othervpnpeers:2500perpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:40.909] Process line = <Total VPN Peers : 2500 perpetual> [33bf2722] [06/10/2021 18:34:40.955] Fuzzy match detector start detecting prompt. String1=totalvpnpeers:2500perpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:41.002] Process line = <AnyConnect for Mobile : Disabled perpetual> [33bf2722] [06/10/2021 18:34:41.034] Fuzzy match detector start detecting prompt. String1=anyconnectformobile:disabledperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:41.080] Process line = <AnyConnect for Cisco VPN Phone : Disabled perpetual> [33bf2722] [06/10/2021 18:34:41.112] Fuzzy match detector start detecting prompt. String1=anyconnectforciscovpnphone:disabledperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:41.159] Process line = <Advanced Endpoint Assessment : Disabled perpetual> [33bf2722] [06/10/2021 18:34:41.190] Fuzzy match detector start detecting prompt. String1=advancedendpointassessment:disabledperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:41.221] Process line = <Shared License : Disabled perpetual> [33bf2722] [06/10/2021 18:34:41.252] Fuzzy match detector start detecting prompt. String1=sharedlicense:disabledperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:41.284] Process line = <Total TLS Proxy Sessions : 2 perpetual> [33bf2722] [06/10/2021 18:34:41.315] Fuzzy match detector start detecting prompt. String1=totaltlsproxysessions:2perpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:41.377] Process line = <Botnet Traffic Filter : Disabled perpetual> [33bf2722] [06/10/2021 18:34:41.491] Fuzzy match detector start detecting prompt. String1=botnettrafficfilter:disabledperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:41.549] Process line = <IPS Module : Enabled perpetual> [33bf2722] [06/10/2021 18:34:41.580] Fuzzy match detector start detecting prompt. String1=ipsmodule:enabledperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:41.612] Process line = <Cluster : Enabled perpetual> [33bf2722] [06/10/2021 18:34:41.643] Fuzzy match detector start detecting prompt. String1=cluster:enabledperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:41.674] Process line = <Cluster Members : 2 perpetual> [33bf2722] [06/10/2021 18:34:42.080] Fuzzy match detector start detecting prompt. String1=clustermembers:2perpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:42.112] Process line = <> [33bf2722] [06/10/2021 18:34:42.159] Process line = <This platform has an ASA5545 VPN Premium license.> [33bf2722] [06/10/2021 18:34:42.190] Fuzzy match detector start detecting prompt. String1=thisplatformhasanasa5545vpnpremiumlicense. String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:42.221] Process line = <> [33bf2722] [06/10/2021 18:34:42.237] Process line = <> [33bf2722] [06/10/2021 18:34:42.268] Process line = <Failover cluster licensed features for this platform:> [33bf2722] [06/10/2021 18:34:42.299] Fuzzy match detector start detecting prompt. String1=failoverclusterlicensedfeaturesforthisplatform: String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:42.330] Process line = <Maximum Physical Interfaces : Unlimited perpetual> [33bf2722] [06/10/2021 18:34:42.362] Fuzzy match detector start detecting prompt. String1=maximumphysicalinterfaces:unlimitedperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:42.393] Process line = <Maximum VLANs : 300 perpetual> [33bf2722] [06/10/2021 18:34:42.440] Fuzzy match detector start detecting prompt. String1=maximumvlans:300perpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:42.487] Process line = <Inside Hosts : Unlimited perpetual> [33bf2722] [06/10/2021 18:34:42.518] Fuzzy match detector start detecting prompt. String1=insidehosts:unlimitedperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:42.549] Process line = <Failover : Active/Active perpetual> [33bf2722] [06/10/2021 18:34:42.580] Fuzzy match detector start detecting prompt. String1=failover:active/activeperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:42.612] Process line = <Encryption-DES : Enabled perpetual> [33bf2722] [06/10/2021 18:34:42.643] Fuzzy match detector start detecting prompt. String1=encryption-des:enabledperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:42.690] Process line = <Encryption-3DES-AES : Enabled perpetual> [33bf2722] [06/10/2021 18:34:43.424] Fuzzy match detector start detecting prompt. String1=encryption-3des-aes:enabledperpetual String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:43.628] Process line = <<--- More --->> [33bf2722] [06/10/2021 18:34:43.674] Fuzzy match detector start detecting prompt. String1=<---more---> String2=hok-ext-vpn-1/pri/stby> [33bf2722] [06/10/2021 18:34:43.721] Send GotAMore request to timer... LastData: <--- More ---> PushBackBuffer: [33bf2722] [06/10/2021 18:34:44.440] TimerTick: mstrData=<<--- More --->> State=Connected [33bf2722] [06/10/2021 18:34:44.455] Pending Disconnect = True [33bf2722] [06/10/2021 18:34:44.502] Force Disconnect by Timer [33bf2722] [06/10/2021 18:34:44.549] StateChange: Disconnecting [33bf2722] [06/10/2021 18:34:44.612] StateChange: Unknown state 'Disconnected'. Changing to default 'StateIdle'. [33bf2722] [06/10/2021 18:34:44.627] StateChange: Disconnected [33bf2722] [06/10/2021 18:34:44.659] TimerTick: Killing session timer. [33bf2722] [06/10/2021 18:34:44.721] Disconnected - From: 10.95.0.173 [33bf2722] [06/10/2021 18:34:44.752] TimerTick: Killing session timer. [9623d334] [06/10/2021 18:35:29.846] -----------------Net. SWTelnet v7.12.4.922------------------- [9623d334] [06/10/2021 18:35:29.846] UseCustomMorePromptBehaviour: False [9623d334] [06/10/2021 18:35:29.909] MorePromptKey: [9623d334] [06/10/2021 18:35:29.971] Custom MorePrompt Pattern: [9623d334] [06/10/2021 18:35:30.018] Login Attempts: 1 [9623d334] [06/10/2021 18:35:30.049] UseKeyboardInteractiveAuthentication: False [9623d334] [06/10/2021 18:35:30.081] Enable Identifier: #$ [9623d334] [06/10/2021 18:35:30.127] Device Template: *** cisco asa *** Connection Profile: cisco asa [9623d334] [06/10/2021 18:35:30.159] System Name: Extranet FW HOK-B [9623d334] [06/10/2021 18:35:30.206] System Description: Cisco Adaptive Security Appliance Version 9.12(3)12 [9623d334] [06/10/2021 18:35:30.269] System OID: 1.3.6.1.4.1.9.1.1409 [9623d334] [06/10/2021 18:35:30.315] UseExactPromptMatch=False [9623d334] [06/10/2021 18:35:30.377] Menu-based mode=False [9623d334] [06/10/2021 18:35:30.411] FreezeLoginForPreCommands mode= False [9623d334] [06/10/2021 18:35:30.440] CommandCharKey = Default [9623d334] [06/10/2021 18:35:30.471] FISP mode= False [9623d334] [06/10/2021 18:35:30.502] UseVirtualPromptForCommands False [9623d334] [06/10/2021 18:35:30.534] VirtualPrompt: > [9623d334] [06/10/2021 18:35:30.565] VirtualEnablePrompt: # [9623d334] [06/10/2021 18:35:30.596] Responce Timeout in seconds: 15 [9623d334] [06/10/2021 18:35:30.627] Connection Timeout in seconds: 45 [9623d334] [06/10/2021 18:35:30.674] Resx Culture is: English (United States) [9623d334] [06/10/2021 18:35:30.706] Encoding: Unicode (UTF-8) [9623d334] [06/10/2021 18:35:30.752] Process Architecture : 64-bit [9623d334] [06/10/2021 18:35:30.799] WOD details: EncryptionAlgorithm: Auto WODSSH Version: 2.8.0.196 WODSSH Assembly Version: 2.8.0.196 WODSSH Assembly location: \Program Files (x86)\SolarWinds\Orion\WeOnlyDo\WeOnlyDo.Client.SSH.dll AllocatePty: True Authentication: Password DebugFile: C:\ProgramData\SolarWinds\Logs\Orion\CLI\Session-Trace\NCM\10.95.0.173-SWTelnetDebug[1].txt EncryptionList: aes128-ctr,aes128-cbc,3des-cbc,blowfish-cbc,aes192-ctr,aes192-cbc,aes256-ctr,aes256-cbc,chacha20-poly1305@openssh.com,rijndael-cbc@lysator.liu.se ExitSignal: FingerPrintType: MD5 FIPS: False ForwardHost: ForwardPort: 0 HMacList: hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-sha1-96 Hostname: 10.95.0.173 KeepAlives: 0 KeyExchangeList: diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ext-info-c KeyFowarding: False Login: solarwind Port: 22 Protocol: SSHAuto ProxyHostname: ProxyLogin: ProxyPort: 1080 ProxyType: ProxyNone RemoteIdentification: ShowStdErrorMessages: True StripANSI: True Subsystem: TerminalType: vt100 Timeout: 45 [9623d334] [06/10/2021 18:35:30.862] StateChange: Connecting [9623d334] [06/10/2021 18:35:32.627] Got HostFingerPrint: System.Byte[] [9623d334] [06/10/2021 18:35:32.737] SWTelnet9 Crypto Information Begin [9623d334] [06/10/2021 18:35:32.768] Protocol = SSH2 [9623d334] [06/10/2021 18:35:32.799] RemoteName = 10.95.0.173 [9623d334] [06/10/2021 18:35:32.846] SCcipher = AES128ctr [9623d334] [06/10/2021 18:35:32.893] CSCipher = AES128ctr [9623d334] [06/10/2021 18:35:32.940] Keys = ssh-rsa [9623d334] [06/10/2021 18:35:32.971] TimerTick: mstrData=<> State=Connecting [9623d334] [06/10/2021 18:35:33.018] SWTelnet9 Crypto Information End [9623d334] [06/10/2021 18:35:33.049] Pending Disconnect = False [9623d334] [06/10/2021 18:35:33.096] TimerTick: not idle, leaving [9623d334] [06/10/2021 18:35:35.174] TimerTick: mstrData=<> State=Connecting [9623d334] [06/10/2021 18:35:35.190] Pending Disconnect = False [9623d334] [06/10/2021 18:35:35.237] TimerTick: not idle, leaving [9623d334] [06/10/2021 18:35:35.315] StateChange: Connected [9623d334] [06/10/2021 18:35:35.362] Connected! [9623d334] [06/10/2021 18:35:35.784] -->ACCESS IS RESTRICTED TO HBL AUTHORIZED PERSONNEL ONLY!!This is a privately owned computing system.Access is permitted only by authorized employees or agents of the company.The system may be used only for authorized company business.Company management approval is required for all access privileges.This system is equipped with a security system intended to prevent andThis system is equipped with a security system intended to prevent andrecord unauthorized access attempts.Unauthorized access or use is a crime under the law.Type help or '' for a list of available commands.ACCESS IS RESTRICTED TO HBL AUTHORIZED PERSONNEL ONLY!! [9623d334] [06/10/2021 18:35:35.815] -->ACCESS IS RESTRICTED TO HBL AUTHORIZED PERSONNEL ONLY!! [9623d334] [06/10/2021 18:35:35.924] -->This is a privately owned computing system. [9623d334] [06/10/2021 18:35:35.971] -->ACCESS IS RESTRICTED TO HBL AUTHORIZED PERSONNEL ONLY!! [9623d334] [06/10/2021 18:35:36.018] -->This is a privately owned computing system. [9623d334] [06/10/2021 18:35:36.065] -->The system may be used only for authorized company business. [9623d334] [06/10/2021 18:35:36.112] -->Unauthorized access or use is a crime under the law. [9623d334] [06/10/2021 18:35:36.159] -->User solarwind logged in to HOK-EXT-VPN-1 [9623d334] [06/10/2021 18:35:36.221] -->Logins over the last 91 days: 192. Last login: 18:35:19 PKT Jun 10 2021 from 10.200.51.3 [9623d334] [06/10/2021 18:35:36.284] -->Failed logins since the last login: 0. Last failed login: 17:12:17 PKT Jun 10 2021 from 10.200.51.3 [9623d334] [06/10/2021 18:35:36.331] -->Type help or '?' for a list of available commands. [9623d334] [06/10/2021 18:35:36.393] --> [9623d334] [06/10/2021 18:35:36.424] -->HOK-EXT-VPN-1/pri/stby> [9623d334] [06/10/2021 18:35:36.456] ProcessLogin State: Banner [9623d334] [06/10/2021 18:35:36.502] no credentials needed - Command mode prompt detected [9623d334] [06/10/2021 18:35:36.550] Prompt being set to: HOK-EXT-VPN-1/pri/stby> [9623d334] [06/10/2021 18:35:36.612] Logged into device [9623d334] [06/10/2021 18:35:36.659] <-- [9623d334] [06/10/2021 18:35:36.784] --> [9623d334] [06/10/2021 18:35:36.799] --> [9623d334] [06/10/2021 18:35:37.596] Start check prompt for menu-based device [9623d334] [06/10/2021 18:35:37.768] Process line = <> [9623d334] [06/10/2021 18:35:37.815] Process line = <> [9623d334] [06/10/2021 18:35:37.924] --> [9623d334] [06/10/2021 18:35:37.940] -->HOK-EXT-VPN-1/pri/stby> [9623d334] [06/10/2021 18:35:37.987] Start check prompt for menu-based device [9623d334] [06/10/2021 18:35:38.034] Process line = <> [9623d334] [06/10/2021 18:35:38.065] Process line = <HOK-EXT-VPN-1/pri/stby> > [9623d334] [06/10/2021 18:35:38.112] SendNextCommand Running: terminal pager 0 [9623d334] [06/10/2021 18:35:38.143] <-- terminal pager 0 [9623d334] [06/10/2021 18:35:38.268] -->terminal pager 0 [9623d334] [06/10/2021 18:35:38.284] --> [9623d334] [06/10/2021 18:35:38.315] Complete buffer is detected - save all lines to the echo buffer [9623d334] [06/10/2021 18:35:38.346] Echo not detected yet. Push back data to echo buffer, EchoBuffer = <<<terminal pager 0 >>> [9623d334] [06/10/2021 18:35:38.393] Start detecting command echo in echo buffer... [9623d334] [06/10/2021 18:35:38.424] Echo is detected, EchoBuffer = <<<terminal pager 0 >>> [9623d334] [06/10/2021 18:35:38.456] RemovePrompt = prompt not found via Regex [9623d334] [06/10/2021 18:35:38.487] Echo and prompt are removed if they exist, out buffer = <<<>>> [9623d334] [06/10/2021 18:35:38.518] Start check prompt for menu-based device [9623d334] [06/10/2021 18:35:38.549] Process line = <> [9623d334] [06/10/2021 18:35:38.721] --> ^ [9623d334] [06/10/2021 18:35:38.737] -->ERROR: % Invalid input detected at '^' marker. [9623d334] [06/10/2021 18:35:38.768] --> [9623d334] [06/10/2021 18:35:38.815] -->HOK-EXT-VPN-1/pri/stby> [9623d334] [06/10/2021 18:35:38.846] Start check prompt for menu-based device [9623d334] [06/10/2021 18:35:38.877] Process line = < ^> [9623d334] [06/10/2021 18:35:38.924] Fuzzy match detector start detecting prompt. String1=^ String2=hok-ext-vpn-1/pri/stby> [9623d334] [06/10/2021 18:35:38.956] Save Command output: ^ [9623d334] [06/10/2021 18:35:39.002] Process line = <ERROR: % Invalid input detected at '^' marker.> [9623d334] [06/10/2021 18:35:39.049] Fuzzy match detector start detecting prompt. String1=error:%invalidinputdetectedat'^'marker. String2=hok-ext-vpn-1/pri/stby> [9623d334] [06/10/2021 18:35:39.081] Save Command output: ERROR: % Invalid input detected at '^' marker. [9623d334] [06/10/2021 18:35:39.127] Process line = <> [9623d334] [06/10/2021 18:35:39.174] Process line = <HOK-EXT-VPN-1/pri/stby> > [9623d334] [06/10/2021 18:35:39.221] SendNextCommand Running: Show running [9623d334] [06/10/2021 18:35:39.268] <-- Show running [9623d334] [06/10/2021 18:35:39.471] -->Show running [9623d334] [06/10/2021 18:35:39.502] --> [9623d334] [06/10/2021 18:35:39.534] Complete buffer is detected - save all lines to the echo buffer [9623d334] [06/10/2021 18:35:39.581] Echo not detected yet. Push back data to echo buffer, EchoBuffer = <<<Show running >>> [9623d334] [06/10/2021 18:35:39.612] Start detecting command echo in echo buffer... [9623d334] [06/10/2021 18:35:39.659] Echo is detected, EchoBuffer = <<<Show running >>> [9623d334] [06/10/2021 18:35:39.831] RemovePrompt = prompt not found via Regex [9623d334] [06/10/2021 18:35:39.909] Echo and prompt are removed if they exist, out buffer = <<<>>> [9623d334] [06/10/2021 18:35:39.971] Start check prompt for menu-based device [9623d334] [06/10/2021 18:35:40.034] Process line = <> [9623d334] [06/10/2021 18:35:40.284] --> ^ [9623d334] [06/10/2021 18:35:40.315] -->ERROR: % Invalid input detected at '^' marker. [9623d334] [06/10/2021 18:35:40.346] --> [9623d334] [06/10/2021 18:35:40.441] -->HOK-EXT-VPN-1/pri/stby> [9623d334] [06/10/2021 18:35:40.487] Start check prompt for menu-based device [9623d334] [06/10/2021 18:35:40.518] Process line = < ^> [9623d334] [06/10/2021 18:35:40.565] Fuzzy match detector start detecting prompt. String1=^ String2=hok-ext-vpn-1/pri/stby> [9623d334] [06/10/2021 18:35:40.596] Save Command output: ^ [9623d334] [06/10/2021 18:35:40.643] Process line = <ERROR: % Invalid input detected at '^' marker.> [9623d334] [06/10/2021 18:35:41.268] Fuzzy match detector start detecting prompt. String1=error:%invalidinputdetectedat'^'marker. String2=hok-ext-vpn-1/pri/stby> [9623d334] [06/10/2021 18:35:41.612] Save Command output: ERROR: % Invalid input detected at '^' marker. [9623d334] [06/10/2021 18:35:41.690] Process line = <> [9623d334] [06/10/2021 18:35:41.737] Process line = <HOK-EXT-VPN-1/pri/stby> > [9623d334] [06/10/2021 18:35:41.784] SendNextCommand Running: show access-list | exclude \ +access [9623d334] [06/10/2021 18:35:41.831] <-- show access-list | exclude \ +access [9623d334] [06/10/2021 18:35:41.971] -->show access-list | exclude \ +access [9623d334] [06/10/2021 18:35:42.002] --> [9623d334] [06/10/2021 18:35:42.034] Complete buffer is detected - save all lines to the echo buffer [9623d334] [06/10/2021 18:35:42.143] Echo not detected yet. Push back data to echo buffer, EchoBuffer = <<<show access-list | exclude \ +access >>> [9623d334] [06/10/2021 18:35:42.190] Start detecting command echo in echo buffer... [9623d334] [06/10/2021 18:35:42.237] Echo is detected, EchoBuffer = <<<show access-list | exclude \ +access >>> [9623d334] [06/10/2021 18:35:42.284] RemovePrompt = prompt not found via Regex [9623d334] [06/10/2021 18:35:42.315] Echo and prompt are removed if they exist, out buffer = <<<>>> [9623d334] [06/10/2021 18:35:42.362] Start check prompt for menu-based device [9623d334] [06/10/2021 18:35:42.409] Process line = <> [9623d334] [06/10/2021 18:35:42.581] --> ^ [9623d334] [06/10/2021 18:35:42.596] -->ERROR: % Invalid input detected at '^' marker. [9623d334] [06/10/2021 18:35:42.643] --> [9623d334] [06/10/2021 18:35:42.690] -->HOK-EXT-VPN-1/pri/stby> [9623d334] [06/10/2021 18:35:42.752] Start check prompt for menu-based device [9623d334] [06/10/2021 18:35:42.831] Process line = < ^> [9623d334] [06/10/2021 18:35:42.877] Fuzzy match detector start detecting prompt. String1=^ String2=hok-ext-vpn-1/pri/stby> [9623d334] [06/10/2021 18:35:42.924] Save Command output: ^ [9623d334] [06/10/2021 18:35:42.987] Process line = <ERROR: % Invalid input detected at '^' marker.> [9623d334] [06/10/2021 18:35:43.034] Fuzzy match detector start detecting prompt. String1=error:%invalidinputdetectedat'^'marker. String2=hok-ext-vpn-1/pri/stby> [9623d334] [06/10/2021 18:35:43.096] Save Command output: ERROR: % Invalid input detected at '^' marker. [9623d334] [06/10/2021 18:35:43.143] Process line = <> [9623d334] [06/10/2021 18:35:43.534] Process line = <HOK-EXT-VPN-1/pri/stby> > [9623d334] [06/10/2021 18:35:43.581] SendNextCommand Done: disconnecting [9623d334] [06/10/2021 18:35:45.487] TimerTick: mstrData=<HOK-EXT-VPN-1/pri/stby> > State=Connected [9623d334] [06/10/2021 18:35:45.518] Pending Disconnect = True [9623d334] [06/10/2021 18:35:45.565] Force Disconnect by Timer [9623d334] [06/10/2021 18:35:45.627] StateChange: Disconnecting [9623d334] [06/10/2021 18:35:45.737] StateChange: Unknown state 'Disconnected'. Changing to default 'StateIdle'. [9623d334] [06/10/2021 18:35:45.768] StateChange: Disconnected [9623d334] [06/10/2021 18:35:45.799] TimerTick: Killing session timer. [9623d334] [06/10/2021 18:35:46.159] Disconnected - From: 10.95.0.173 [9623d334] [06/10/2021 18:35:46.190] TimerTick: Killing session timer.
@makecrazy, this seems to be the issue. Have you confirmed that your device template assigned to the ASA is valid and accurate?
from where i can get valid and accurate template for cisco ASA 5545
@makecrazy, is this ASA a multi-context ASA? if so you'll probably have to do something along the lines outlined in this KB ArticleEdit a Device Template KB
