I am looking into how to configure syslog forwarding from SolarWinds to another syslog server, is that possible on Orion 2020 without Kiwi?
Also, assuming it would be able to maintain IP and message information from the original sender..?
Thank you!
Assuming you are using Orion Log Viewer you can do it from here see KB below
Log forwarding (solarwinds.com)
Worked perfectly - thank you!
