What features are you interested in seeing implemented in any of the products from this mission that aren’t available today? (VMAN, SCM, Log Analyzer, or SAM)
We're not currently using SCM. We might be able to add it as some point in the future.
Not a user, but interesting to read some of these.
currently do not use SCM
@yumdarling Could not vote
wow
We use only NPM, SAM and NTA. CatTools still does what we need in configuration and change management land.
