What features are you interested in seeing implemented in any of the products from this mission that aren’t available today? (VMAN, SCM, Log Analyzer, or SAM)
We use only NPM, SAM and NTA. CatTools still does what we need in configuration and change management land.
wow
@yumdarling Could not vote
currently do not use SCM
Not a user, but interesting to read some of these.
We're not currently using SCM. We might be able to add it as some point in the future.
do not use SCM heavily
Don't use it.
NCM only, I don't use SCM.
I agree - visual overhaul!
Don't use SCM
it's single pane, who did what & how did it hurt. I've only licenced SCM for our Orion servers, so far, but it's soooo goood.
Just curious if any of you are using NCM today?
not using SCM.
WE do not use SCM
Not a member of the SCM club
Mapping Cloud resources
With Orion all the tool kits are helpful with one pane!
Don't use
We're not yet a hybrid organization.
I don't personally use.
none
we don't use it.
We don't use this tool
It would be awesome if there was a way to add notes and comments when issues occur and are visible with these tools. Those notes could be automatically tagged by the condition of the server/application at the time of the issue and when issues arise in the future, SolarWinds could give you the relevant notes from the previous issue.
Pie in the sky idea
Great comments.
We don't use it.
UI/Navigation on NPM could be better.
VMAN
It's not that we're using SCM, I think SCM has some inherently good features to primarily support change management. Other benefits like investigation into life cycle changes to improve performance, security, or changing organizational policies (business initiatives).
The product's benefits are stated simply, but there are some further reaching results that can accrue from usage.
My organization is interested in features that make it easier to report on or display in a widget all expiring certificates that meet date requirements. We have tried all of the scripts, and SAM application monitors that exist for this, but it really takes some tweaking, and displaying the data in a usable format is very difficult.
None. We dont currently use any of those products.
Since I don't use it, I'm not sure....
Not necessarily a feature but a rework of the graphics to make it look more up to date.
