What features are you interested in seeing implemented in any of the products from this mission that aren’t available today? (VMAN, SCM, Log Analyzer, or SAM)
Not necessarily a feature but a rework of the graphics to make it look more up to date.
Since I don't use it, I'm not sure....
None. We dont currently use any of those products.
My organization is interested in features that make it easier to report on or display in a widget all expiring certificates that meet date requirements. We have tried all of the scripts, and SAM application monitors that exist for this, but it really takes some tweaking, and displaying the data in a usable format is very difficult.
It's not that we're using SCM, I think SCM has some inherently good features to primarily support change management. Other benefits like investigation into life cycle changes to improve performance, security, or changing organizational policies (business initiatives).
The product's benefits are stated simply, but there are some further reaching results that can accrue from usage.
VMAN
Don't use
UI/Navigation on NPM could be better.
We don't use it.
Great comments.
It would be awesome if there was a way to add notes and comments when issues occur and are visible with these tools. Those notes could be automatically tagged by the condition of the server/application at the time of the issue and when issues arise in the future, SolarWinds could give you the relevant notes from the previous issue.
Pie in the sky idea
We don't use this tool
we don't use it.
none
I don't personally use.
We're not yet a hybrid organization.
With Orion all the tool kits are helpful with one pane!
Mapping Cloud resources
Don't use SCM
Not a member of the SCM club
WE do not use SCM
not using SCM.
Just curious if any of you are using NCM today?
it's single pane, who did what & how did it hurt. I've only licenced SCM for our Orion servers, so far, but it's soooo goood.
I agree - visual overhaul!
NCM only, I don't use SCM.
Don't use it.
do not use SCM heavily
