Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Map Icons display wrong on web page
tom-g
I have several maps, and when you look at them in map maker, they are displayed with the proper icons. On the website however they show up as cirles. Everyone accessing the site is seeing the same wrong images. Does anyone have any suggestions.
Tom
Find more posts tagged with
Accepted answers
All comments
jtimes
What Icons are you using? If you size them to small in map maker, they display as dots on the web page. Have you tried to re-sized the icons just a little bit larger?
tom-g
I am using larger icons, the dots are showing up pretty big
jtimes
okay... Which Icon group are you trying to use?
Are you creating the map(s) on the server via RDP or Terminal Services? or are you using remote admin? Either way try resizeing your desktop to match the servers display settings when you edit the map and save it.
John J. Times
FormerMember
I've had the same issue... I used a network cloud in my map maker and it's getting pushed out to the website as a common circle/dot.
btorsey
Same problem here: mapmaker shows them correctly as clouds, web pages shows them as generic dots.
jtimes
cloud... there are several cloud icons some scale/display better than others. Generally anything smaller than 20x10 is going to show up as a circle.
Network Devices - Cloud, X.25
Devices - Cloud1
Shapes - HollowCloud2, HollowCloud2Black, HollowBlack
tom-g
I have buildings, servers, network switches, all kinds of things and everything is a circle. It worked fine when i was running 7.8.5. I am now running 8.0.2
tom-g
Does anyone have any other suggestions for this. It is making the maps look horrible and i really want them to display correctly again
billh
Same issue here...I posted a while back and no resolution.
bleearg13
I had this problem with 6.x, I believe. Do you configure the maps using Remote Desktop? If so, can you try configuring a map from the console of the Orion server? If that does not solve the problem, I remember that when I was having the issue, the problem was with the icons that Solarwinds packaged with the older versions of Orion.
Two possible explanations:
www4.solarwinds.net/.../topic.asp
support.solarwinds.net/.../ProblemDetail.cfm
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
