Need below information :
1. Why do we require credential of the system while configuring HA proxy ? Ref Link : https://thwack.solarwinds.com/t5/SAM-Documents/Haproxy/ta-p/537911
2. Can it work with HA proxy username and pwd(read-only) ? or can we monitor it by snmp ?
3. Does Azure HaProxy also require system credential or Point No. 2 will or ?
Hi there, the post you referenced is for SAM, which is our on-premises software using SAM application templates. Are you using AppOptics or SAM? For AppOptics monitoring, you can refer to our documentation here: https://documentation.solarwinds.com/en/success_center/appoptics/content/kb/host_infrastructure/integrations/haproxy.htm
