I keep getting an error popup whenever I try and complete one of the onboarding questions.
The error states "Unauthorized: Only administrative users can write that type of content metadata."
Is this normal?
Looks like it's working now If anyone is having issues, let me know!
Same for me! And no points being added even though I've completed the mission.
Hey @smttysmth02gt
Did you complete the entire mission and not get points?
Yum
Correct.
Hey @glmurphy,
While I try not to judge what's "normal" and what's not... I AM 100% sure you should be able to complete the onboarding mission. Could you imagine what would happen to me if I put something out there that's incomplete-able?! There would be mutiny...
Let me see what's what I'm sure we can get it fixed.
WELL! That's annoying...
Hi yumdarling,
Same issue here, every questions / item checked gives a red popup & no points awarded.Just wanted to let you know.
regards,
Alain
Ya I have done at least 3 Status updates and it shows I still need to do so, but I have green checks on all the rest. I also saw that error message, but it marked a green check anyways so looks good to me.
Hey @jolson1,
I think if you refresh your page all the checkmarks will go away... BUT HAVE NO FEAR - we're working on fixing the issue and then all you'll have to do is click those "check status" buttons again and all should be right with the world.
Thanks Alain! Yeah, seems to be broken for some reason. I'm pretty sad about it, but we're working to fix it asap
All green now, thanks Yum
I should have read the comments before completing the tasks . Well ive completed them all for when they are fixed.
I'll keep checking back. Got all green marks, no points and when I refreshed all the check marks went away. Also received the errors and it took several tries to get the status update to finally work. Thanks.
I'll post on this thread when it comes back to life
Thanks, @yumdarling
Like others, I received the same messages (1 p.m. today, 4/26/2021). But I was able to complete the page successfully, even though they popped up.
All's working well, outside of the popups. And in this case, they don't see to matter.
Rick Schroeder
In The Little Red House
In The Saginaw Wood
Like a charm
Works perfectly! Thanks for the prompt attention!!
