hi
i need to link report by custom html , tried but getting whole page .
It might be better to add the report to the Web Console rather than displaying the HTML page. There are a few different ways of approaching displaying this kind of information.
support.solarwinds.com/.../Add-a-report-to-the-Orion-Web-Console-in-a-resource
thanks
