Hi
Kindly help me to generate report in SQL
Node Custom Property = ATM_Branch
Sample Interval:: Day
Need this average availability report of yesterday.
plzzz help
What do you need to create this report in SQL for? If you are using a custom table, when selecting your Data Source, use the Dynamic Query selection > then object type of Nodes, and then use the "select field" section to select your Custom Property of ATM Branch.
need this report from sql
It looks like you are creating multiple posts on the same topic - placing link to other post: https://thwack.solarwinds.com/product-forums/network-performance-monitor-npm/f/forum/90392/need-help-is-swql-query
