Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
NetFlow Traffic Analyzer (NTA)
If you are not seeing netflow traffic
wtan2000
I have SQL on a separate server, and both servers exceeding recommended specs. The "Active netflow Sources" area was reporting NO active sources for the last 5 minutes.
I installed the netmon sniffer (an optional windows component) onto my Orion server, and saw several packets of port 2055 traffic coming in every minute.
When I edited the resource on the "Active netflow sources" section to show sources for the last 30 minutes, my sources showed up.
My conclusion is that there is a bug in the "last X minutes" section of the code, as I clearly observe data coming in.
Find more posts tagged with
Accepted answers
All comments
dperdue
Is there any time discrepancy between the clock on your SQL Server and the clock on the web server?
David Perdue
SolarWinds Development Team
jshepherd
I have a similar issue in that the default NetFlow page does not show up with the most recent data. The Orion pollers and web server are set to UTC as well as the monitored devices. The backend SQL Server is apparently set for local time (EST), since the difference in timing between the last Netflow data point and the current Orion time is 5 hours. So, are these apps (NetFlow and Wireless) getting their data time stamps from the SQL Server, or is there another app that needs to be adjusted?
Jim Shepherd
Network Services Project Manager - IT
Swiss Reinsurance Company
jsohotha
I had my netflow sources disappear off the active netflow sources also. Restarting the netflow service on the orion box solved my problem.
I am also using a seperate SQL server for the database storage.
savell
Just had the same (kind of) issue.
Added a new netflow source - but it didn't show up as an active netflow source.
Restarted the netflow service and the device and interfaces appeared.
Sav.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
