Quite so
Compute has become the center of so much of life that monitoring has become much more than the old up/down of the past. The experience is critical. It's been proven that being without service in many areas is easier for individuals to deal with than slow or unreliable service.
It is important in that it gives us data on their experience and of how it works from their perspective
On another important note - GO VOTE FOR DR. TEETH on the brackets. RIGHTNOW!
I mean...why am I doing anything if the end-user can't use it?
