Hello,There is any way how i can import the olds devices, users, ... from the old plateforme and import them to the new platforme?
The simplest way of exporting devices out of one Orion instance and into another is to create a report containing only the IP addresses managed by Orion. Run the report and export the results as CSV. Then copy/paste that information into the Sonar Discovery Wizard of your other Orion instance. This will target only those IPs.
how can I export the devices from our old platform(NPM 10.7, NCM7.2.2, NTA 4.0.2)?
I can't do that
Import the following report
https://thwack.solarwinds.com/content-exchange/the-orion-platform/m/reports/2128
Run the report and click 'Export to Excel'.
Copy/paste those results to Sonar Discovery as shown in my previous response above.
Really I don't undrustand this point, how export from the old platform and import from new platform
You will need to rephrase the question and be more specific with your ask, as I have answered this question broadly in the thread above. If there is a particular detail you are not understanding, please state clearly where you are having problems or what specific step is unclear. I'm happy to help, but simply restarting the original question again will not produce a different result.
The steps i laid out above will allow you to export a list of nodes managed/monitored in Orion, then import that list into another Orion instance to be discovered. This is the simplest, and fastest method of exporting and importing nodes from one Orion instance to another.
I don't understand How I export the file.csv and import in the new platform.
-our old platforme is composed by : NPM 10.7, NCM 7.2.2, NTA 4.0.2
-our new platforme is composed by :Npm, nta and ncm 2020.2.4
I don't have scan the network using the following pulling engine:
