I am looking for a way to display the GlobalProtect VPN statistics on the collapsible menu on the landing page in NPM. I have 4 firewalls that I would like to display as a quick-link.
Make sure you have the REST API enabled and CLI polling enabled on your Palo's,
Then see attached.
I will check this out. Thank you.
Alex - im very interested in what you ahve done here. Is this a report? I have been able to get most of it, but where did you find the "Number of Sessions" column? i do not see that.
Alex,
I am trying to add this also, but do not see the "Number of Sessions" as an option to add to this.
Can you detail how you added this?
can you elaborate on what you created here?
