Hi ,
Has anyone tried to do grouping in modern dashboards for custom table?
I am not able to do grouping based on custom properties. Please help me out
Also, please do share new ideas for modern dashboards.
Thanks in advance.
@AlexSoul@aLTeReGo
I have used it a few times, and it should work, show me what you want to do and we can work through it. Below is an example that I used. (the order by gets ignored I think but you can do 'stuff' to order it in the widget I think)
Hi @jm_sysadmin,
Thank you for your response. You can see below query where I am trying to group by but facing error.
SELECT' '+ N.Caption AS NODE --/Orion/View.aspx?View=NodeDetails&NetObject=N:${NodeID},CONCAT('/Orion/images/StatusIcons/small-',ToString(N.StatusLED)) AS [_IconFor_NODE],C.ComponentName AS CMPNT --/Orion/APM/MonitorDetails.aspx?NetObject=AM:${ComponentID},A.Name AS APP --/Orion/APM/ApplicationDetails.aspx?NetObject=AA:${ApplicationID},' '+ C.StatusDescription AS Status,CONCAT('/Orion/images/StatusIcons/small-',TOString(C.StatusDescription),'.gif') AS [_IconFor_Status],N.DetailsURL as [_Link_for_NODE],A.DetailsURL as [_Link_for_APP],C.DetailsURL as [_Link_for_CMPT]FROM Orion.APM.Component CINNER JOIN Orion.APM.Application A ON a.ID = C.ApplicationIDINNER JOIN Orion.Nodes N ON n.NodeID = A.NodeIDINNER JOIN Orion.NodesCustomProperties NCP ON NCP.NodeID=A.NodeIDWHERE
N.Status<>'9' AND NCP.ASP30 = 'True' ANDC.StatusDescription Not in ('Up','Unmanaged','Disabled','Critical','Warning') -- Component is not UpOrder by N.NodeID ASC
Group by NODE, CMPT, APP, Status, [_IconFor_NODE], [_IconFor_Status], [_Link_for_NODE], [_Link_for_APP], [_Link_for_CMPT]
Note : If I don't use grouping then I will get proper output. But I want to group it by Node first and then as mentioned above.
Change the Group By to use the Columns from the SWQL views we have like:
Group by N.NodeID, N.Caption, C.ComponentName, A.Name, C.StatusDescription, N.StatusLED, N.DetailsURL, A.DetailsURL, C.DetailsURLOrder by N.NodeID ASC
We are able to group by NodeName but we are seeing multiple Node Name entries. When we tried from web report or report writer, we are seeing one Node name entry.
The group by functionality in the web report/report writer is not at all the same thing as doing a SQL/SWQL group by. Thats really just a presentation layer kind of thing and there is no SQL equivalent to do that.
