Hello,
Is there an option to add a custom dashboard to a summary view of a group or add it as a tab.
John
Hi John, Yes,there are many options for classic views and modern dashboards depending on what you want to achieve. You can add items to users menu bar https://documentation.solarwinds.com/en/Success_Center/orionplatform/content/core-setting-default-account-menu-bars-and-views-sw2030.htm
or create a modern dashboard and use that URL for a menu item https://documentation.solarwinds.com/en/Success_Center/orionplatform/content/core-fusion-dashboards.htm
Let me know what your specific objectives are and I can provide more guidance.
Hi Tony, a little background info I have one page where all our operating companies are stored. We want to create or a button or a menu option to go to the different dashboards that we will create for all the OC's. Is this possible?
Why not use Orion Maps? You could literally nest groups, other maps, or icons with links to dashboards. A quick example can be seen below...
These could represent each OC in your example. A number of other examples available here.
Love the fancy icons. I use a web resource called flaticon for free icons to represent a lot of the services on my dashboards.
Great Tip @[Deleted User]!
