i tried to run install with hotfix 2, but installer gave me an information "All products are up-to-date."The same was with HF1.
Anyone has the same problem ?Piotr
I had when I tried to run HF2-update on my 2020.2 platform.HF2 is only for 2020.2.1, check your version please
Same issue.
Do you mean HF1 needs to be installed before moving to HF2?
As I understood, "2020.2.1" is not a "2020.2 + HF1".I mean you need a "2020.2.1" release to install HF2.
2020.2 Release date: June 4, 20202020.2.1 Release Date: August 25, 2020
So firstly you need an update 2020.2 -> 2020.2.1 (be careful, I have errors while updating)
I tried upgrading to 2020.2.1 first. It is giving me the same message - "All products are up-to-date"
are you doing online or offline installation?
I tried with offline update, with no success.dunno about online but seems like it includes HF2
This is what I see.
Well I can only advise you to download a full iso distribution (5,1Gb+) from here https://customerportal.solarwinds.com/downloads/and try to perform an offline update. Don't forget for backups
Hi i downloaded Orion Network Performance Monitor (NPM) for Online Installation (recommended) - includes latest released hotfix 2020.2.1 25 AUG 2020and it seems installer contains latest HF2 too ....
Yes, both installers (online and offline) contains HF2.
