Hi, May I need your advice, I am currently using LEM version 6.6.0 but I could not login using web browser due to adobe flash player EOL.
If I upgrade to 6.7.0, do you think can solve this issue?
Thank you.
Hi
Yes we started moving away from Flash in 2019.
Here's the release notes for 6.7, and I suggest to check the other ones at the left hand side:
https://documentation.solarwinds.com/en/success_center/SEM/Content/Release_Notes/SEM_6-7_Release_Notes.htm
Hi saschg,
Thank you for you information and assistance.
I tried to upgrade using cmc but show me "The license maintenance period has expired or no license is installed."
Kindly please let me know if you have a way to run the upgrade for Version 6.7.0
Hi sasch,
I have upgraded to SolarWinds-SEM-6.7.0-Upgrade.iso using cmc. When I connect thru web browser still asking for adobe flash player.
Kindly please advice, thank you.
Open the web browser still using http://xx.x.xx.xxx:8080/lem/
Cannot with http://xx.x.xx.xxx:8080/sem/
It seems you need to renew the maintenance contract as it probably run out a few years ago.Please find more information here:https://www.solarwinds.com/maintenance
I upgraded "SolarWinds-SEM-6.7.0-Upgrade.iso" successfully with cmc upgrade command.
I can see the version indicated 6.7 and I can connect using http://10.1.xxxx/webui/
From this screen, I can see: event, Nodes, Rules, SEM Concole, my account, setting, and "?"
I try to use http://10.1.xx.xxx:8080/sem but show me below error (before I always use http://10.1.xx.xxx:8080/lem to generate the reports using nDepth).
HTTP Status 404 - Not Found
Go to LEM UI
Thank you very much for your advice.
Hi RobBarbieri,
Can I verify for:
1. http://x.x.x.x:8080/lem/ -> Legacy Flash Console - this connection still using adobe flash player, am I correct?
2.http://x.x.x.x:8080/webui/ -> HTML5 Events Console - I can open and access this but I cannot find the dashboard (see the attached screenshots). How to get the dashboard?
Thagin,
I am having same issue. Maintenance contract is current, but been a while since I have been in GUI. When I try to upgrade via CMC I get same message. How were you able to resolve?
rcsteve,
Please reach out to Support, we can assist with getting the license added and helping you upgrade.
Chris
