Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Auto startup of Network Performance Monitor
ajdibble
Am I the only one who thinks it would be very useful for Network Performance Monitor to be able to run as a service, so it starts logging immediately the machine restarts and you don't have to log on?
Anthony
Find more posts tagged with
Accepted answers
All comments
Network_Guru
This was the biggest improvement done to the Orion product.
Unless they are planning on adding this to the Solarwinds products,
you may need to "upgrade" to Orion if you want this feature.
-=Cheers=-
NG
Bryan
I added a shortcut to the Network Perfmon executable to my startup folder along with the syslog server, tftp server and advanced cpu monitor. This seemed to fix my problems. I had tried to used a program called srvany. This creates registry entries for programs so they show up as services. I noticed problems with certain features when I tried it this way. I agree, solarwinds should just make it default or at least an option to run as service.
Bryan
Lockheed Martin
Atlas V Launch Operations
Network Engineer
ajdibble
Beautiful in its simplicity! Excellent idea. I've also combined that with autologon so it works even if the PC is rebooted for any reason. For anyone that's interested, on WINNT/W2K you need to add/edit the following registry settings:
In:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Assign appropriate values to the following:
DefaultDomainName DefaultUserName DefaultPassword
(Data type REG_SZ)
Set AutoAdminLogon to 1 (Also a string)
Thanks for that Bryan. If anyone from SolarWinds is listening in, we still think the facility should be there to allow running as a service though!
Anthony
Corus Strip Products, UK
Bryan
Sorry I forgot to mention that. I had also used to auto logon for the same reason. That way if the computer loses power, it will come back up on its own. I also invoked the screensaver.exe in the startup folder with password so no one would try and mess with anything...
Lockheed Martin
Network Engineer
ayehia
You can make system schudle on computer restarts , runs specific exe,
so when it restarts , it will work and collect data
i use this already
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
