I am trying to upgrade to HF2 and i keep getting a license error for NCM. I used to have NCM but have moved to NAM which includes NCM. What can I do? Waiting on support is useless at this point.
Product license expiredDISCOVERED: 12/17/2020 10:46:53 AMDESCRIPTION: Maintenance expired for: Network Configuration Manager Renew now: https://customerportal.solarwinds.com/renew-maintenance/renewRESOLUTION: You must renew your maintenance to upgrade.https://customerportal.solarwinds.com/renew-maintenance/renewVerify your license status on:
@emunizaga - Sounds like the licensing issue was resolved and you have been able to upgrade. Glad you were able to get sorted.
You can uninstall NCM from add/remove programs since it is packaged in with NAM.
I un-installed NCM from add/remove programs. Now i can't install anything. Good thing i took a snapshot of this VM. Will never listen to thwack again.
@emunizaga can you share the footer of your deployment so that we can see the version you are running? And perhaps also include a screenshot of your License Manager.
@jblankjblank
@emunizaga - can you also confirm your SWID please? Feel free to direct message me.
