I have an existing license on this for 500 devices, its been outstanding job to be done, would Solarwinds honour the license to new product, as a school its not easy to find money for license cost on such a product.
To date backup database from old server SQl Express 2005 to copy and restore on SQL 2008 R2 but fails to configure DB
Thanks for your support, I keep on getting a common problem in configuration of existing DB NetPerfMon this is the result.
Database configuration failed:
• Could not Alter DataType of Accounts.AccountID to varchar(100)[SQL-DMO]This index was generated by a DRI 'PRIMARY KEY' or 'UNIQUE KEY' CONSTRAINT and cannot be modified or dropped.
This is in the process of Update from NPM 9.1 - NPM 9.5
Does there need to be an sql script on this to allow DB to be modified tried on several blogs, changed Host name to DB
Further issues if creating new DB
• Exception while configuring plugin Orion Network Performance Monitor component Orion Network Performance Monitor Database. [Microsoft][ODBC SQL Server Driver][SQL Server]The query uses non-ANSI outer join operators ("*=" or "=*"). To run this query without modification, please set the compatibility level for current database to 80, using the SET COMPATIBILITY_LEVEL option of ALTER DATABASE. It is strongly recommended to rewrite the query using ANSI outer join operators (LEFT OUTER JOIN, RIGHT OUTER JOIN). In the future versions of SQL Server, non-ANSI join operators will not be supported even in backward-compatibility modes.
Does the DB of existing NetPerfMon have to have change on ANSI or is there options on SET COMPATIBILITY_LEVEL
Please excuse me as I am not trained on SQL, if you send a reply could you break it down in parts of what needs to be done or point me in the right direction to resolve this issue.
I understand that this is being migrated from windows 2003 server to either Windows 2008 R2 that I think should work out of the box, but may be the Windows 2016 with SQL 2008 is a bit much of an ask.
