Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Using Terminal Services
mnwild_mntwins
We run our Engineers edition on a server in our data center. Any admin that needs to use the software will connect to the server via RDP. The problem we have is; if somebody is RDP'd into the server and working on something and somebody else logs in, the first user gets "booted" out. There is no warning or dialog window, it just disconnects them. Has anyone else run into this issue? If so, what is a workaround? Sorry for the elementary question, but I am not a Windows admin just a network admin.
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Use Win2k or Win2k3 Server edition for your EE server.
You can have 2 simultaneous RDP sessions up, or an RDP session directly to the console
as well as one remote RDP session up. You cannot get knocked out of your session, as the user trying to login will be notified the maximum # od session has been exceeded on the server.
There is a way of checking if someone is using RDP on a WinXP PC before connecting remotely (I don't have the specifics right now).
Try a Google search for WinXP RDP...
-=Cheers=-
NG
mnwild_mntwins
This should fix the issue:
Open the Terminal Services Configuration Tool: click Start, point to Administrative Tools, and then click Terminal Services Configuration.
In the console tree, click Connections.
In the right pane, right-click RDP-Tcp, and then click Properties.
On the Network Adapter tab, click to select 1 from the Maximum connections drop-down list
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
