Hello all,
I'm currently trying to plan an architecture to move our Orion into Azure. I'm trying to do this as securely as I can with the goal of placing an AWS (Additional Web Server) into a DMZ for public access possibly. What I keep running across is that a requirement I'm reading on the scalability guidelines is that an AWS requires a direct 1433 connection to the Orion database. This requirement ultimately kills my middle tier strategy. Meaning having a DMZ for the web server(s), a middle tier for the MPE and APEs, and a backend tier containing the database.
Has anyone ran across a way to do this securely? Have you done this yourself and have some suggestions?
Ultimately, I could limit the port and perhaps change it from a non-standard one and use SQL authentication only there, but still seems like a security risk.
Thoughts?
