Hello,
I have an issue with Network Atlas, I want to map the links to some device interfaces, in the first time before I add the device to the map I can map its interfaces to those links, but once I add the parent device I can't view its interfaces (Picture_1), I have tested the same thing in a test platform but it works as you see in Picture_2 (I can see the interfaces after adding the parent device to the map).
Thank you for your support.
Best Regards
MERFOUK Mouad
