Once i upgrade the Orion server to HF2, do i upgrade all the polling engines again? Thanks.
Yes, you need to apply HF2 to the primary poller first, then all the additional pollers, running config wizard on each in turn to finalize installs.
Thanks. Can i just download the installer right off the UI once I upgrade the core server?
