The Macro for ${IP} is not returning the IP. Am I using it wrong, or is this a bug?
What's the context? Is this in an alert or somewhere else?
Also, which version?
I am talking about in the message sent for an Advanced Alert.
Orion 8.1.0
Try using ${IP_Address}. This should work.
Regards,
SAM
Nope, ${IP_Address} did not work either. I got an alert this morning and it says ${IP_Address} instead of providing the actual IP address, same as before with ${IP}.
Also, my rule says alert if greater that 80, but I am getting an alert when the threashold hits 9.
Try ${Node.IP_Address}
JB
The last suggestion ${Node.IP_Address} worked. Thank you.
