I'd like to build a view where I can see Disk Volumes (as it appears in the default node details screen) from multiple nodes on a single screen. Has anyone found a way to build a custom view like this?
This page explains how to do this for Network Interface Percent Utilization graphs or gauges, but the methodology is the same for Disk Volumes:Display multiple Interface resources in one page - SolarWinds Worldwide, LLC. Help and Support
Just select the disk volumes and gauges or graphs you want to display on the same page.
Thank-you for the reply.
I have used this method for graphs successfully. My problem still exists for the disk volumes though. When you do a view source on the volumes all the numbers (like percent used, etc.) are hard coded into the html so when you paste it into a custom tag it appears correctly but will never update.
Any thoughts on how I get the Disk Volumes to work?
I have built a report with the same information but I like the look of the node details Disk Volume a lot more.
Detach the resource and paste in the URL of the detached view, rather than the properties:
OrionServer/.../DetachResource.asp
Not sure if this is what you are looking for?
Yes, that is what I'm looking for. I'll try again. I don't actually have the "detach" button as shown in the instructions so I'll find the option I need to change to show that (I'm assuming there is one somewhere).
Thanks.
Click on the resource title and it will detach.
Yeah, that's what I did originally but the view source from that doesn't work.
So now I understand I need to use the URL. That makes sense. But I can't just paste that into the Custom HTML object or what I get is the url text (not surprisingly). Do you normally put this in a frame or the src for an image tag? I'm just curious what you use. I've used frames for this in the past.
<br><img src="/NetPerfMon/Chart.asp?Chart=MMAvgUtil&NetObject=I:5309&Period=Last%2012%20Months&SampleSize=1D&Title=Call+Center+Link+%231&SubTitle=Backbone+link+to+AB+%26+ON&ReBuild=TRUE&FontSize=Medium&Width=480&Height=400"><br><img src="/NetPerfMon/Chart.asp?Chart=MMAvgUtil&NetObject=I:5311&Period=Last%2012%20Months&SampleSize=1D&Title=Call+Center+Link+%232&SubTitle=Backbone+link+to+BC+%26+ON&ReBuild=TRUE&FontSize=Medium&Width=480&Height=400"><br>
Just replace the italicised code between the quotes with the URL you want to display on the page.<br> adds a line feed between images.
You can use any basic WYSYWIG web editor to create any page you want to display in Orion (including external sites).
