Hi i'm fairly new to this, but i think i'm beginning to see a pattern in other threads, but any advice gratefully received.
I am evaluating this product, to roll out to a number of our supported clients, not all have a full Cisco estate. One product i am trying to work with, should work fine as it's config is in clear text. The issue revolves around the telnet credential's. They are correct and work from a Telnet session, but when i verify the login credentials, i see Cirrus, successfully logging in, then waiting. Eventually the "bad password" message is displayed. I think i know the problem, the telnet login banner once authenticated is just a $ (It can't be changed either), I think this is similar to the Cisco # issue. Is it possible to change Cirrus to look for the $ or ignore it?.
Chris M
