Since NPM is vastly superior in its ability to query and report on the SQL database, why couldn't we have the ability to point to the NCM Database and write reports from it?
Specifically, I would like the sort functions at the header line so that reports can be sorted as well as building a report without having to process the entire database every time I change something.
Secondly,I would like to have ability to display custom properties from NCM's database for Nodes in NPM that are being looked at ont he Node Details page.
I hope that this makes sense.
Thanks for the consideration.
