I see it in Manage Views but haven't found where to bring it up.
pyro13g,
Do you have any CBQoS resources on a Device Details view for a monitored CBQoS-enabled device?
Yes, but for the view in question, here is the error:
Please notify SolarWinds of this error. We will address and help you fix the issue.
Your specfic error is:
This view type (CBQoS) requires a net object and none has been specified.
Trying to figure out where the NetObject would go in the URL /Orion/TrafficAnalysis/NetflowCBQoSDetails.aspx?viewname=CBQoS%20Details
I see what's happening. It's bringing resources up for:
CBQoS Pre-Policy Map
CBQoS Drops
CBQoS Post-Policy Class Map
CBQoS Policy Details
On some interfaces but not others, even though there is QoS on the interface(and it's the same router). Now to figure out why.
Can you confirm from your CBQoS config on the parent router that your CBQoS policies are actually applied to the interfaces for which you are trying see these resources?
Yep, that is why it is so confusing. I used to display the CBQOS mibs for each router and they would be there.
Here is show policy-map interface for one that the resources do not display for:
Multilink10 Service-policy output: BSI_COPLEY Class-map: premium (match-all) 153017614 packets, 21260713319 bytes 5 minute offered rate 353000 bps, drop rate 0 bps Match: ip dscp ef (46) Queueing Strict Priority Output Queue: Conversation 264 Bandwidth 30 (%) Bandwidth 921 (kbps) Burst 23025 (Bytes) (pkts matched/bytes matched) 46296041/7114522772 (total drops/bytes drops) 2743/443322 Class-map: signal (match-any) 13754027 packets, 1070772952 bytes 5 minute offered rate 5000 bps, drop rate 0 bps Match: ip dscp cs3 (24) 13754027 packets, 1070772952 bytes 5 minute rate 5000 bps Match: ip dscp af31 (26) 0 packets, 0 bytes 5 minute rate 0 bps Queueing Strict Priority Output Queue: Conversation 264 Bandwidth 5 (%) Bandwidth 153 (kbps) Burst 3825 (Bytes) (pkts matched/bytes matched) 3220411/285300671 (total drops/bytes drops) 1077/237908 Class-map: BSI_notbesteffort (match-all) 294306316 packets, 113994186522 bytes 5 minute offered rate 375000 bps, drop rate 0 bps Match: not access-group name email Match: not access-group name internetproxy Match: not access-group name landesk Match: not access-group name symantec_av Match: not access-group name vontu Match: not access-group name MSDNS_T Match: not access-group name NBSSN_T Match: not access-group name ucprod Queueing Output Queue: Conversation 265 Bandwidth 30 (%) Bandwidth 921 (kbps) (pkts matched/bytes matched) 160981149/84972686666 (depth/total drops/no-buffer drops) 2/195337/0 exponential weight: 9 mean queue depth: 6 dscp Transmitted Random drop Tail drop Minimum Maximum Mark pkts/bytes pkts/bytes pkts/bytes thresh thresh prob af11 0/0 0/0 0/0 32 40 1/10 af12 0/0 0/0 0/0 28 40 1/10 af13 0/0 0/0 0/0 24 40 1/10 af21 3838993/217992902 149/7863 21/1265 32 40 1/10 af22 0/0 0/0 0/0 28 40 1/10 af23 22788473/5331321614 5861/1574052 119/40845 24 40 1/10 af31 0/0 0/0 0/0 32 40 1/10 af32 0/0 0/0 0/0 28 40 1/10 af33 0/0 0/0 0/0 24 40 1/10 af41 11/1766 0/0 0/0 32 40 1/10 af42 0/0 0/0 0/0 28 40 1/10 af43 0/0 0/0 0/0 24 40 1/10 cs1 0/0 0/0 0/0 22 40 1/10 cs2 0/0 0/0 0/0 24 40 1/10 cs3 0/0 0/0 0/0 26 40 1/10 cs4 0/0 0/0 0/0 28 40 1/10 cs5 0/0 0/0 0/0 30 40 1/10 cs6 343841/31920455 2/110 0/0 32 40 1/10 cs7 0/0 0/0 0/0 34 40 1/10 ef 0/0 0/0 0/0 36 40 1/10 rsvp 0/0 0/0 0/0 36 40 1/10default 267139661/108281295540 187912/129178242 1273/757447 20 40 1/10 Class-map: class-default (match-any) 70255840 packets, 53686575703 bytes 5 minute offered rate 495000 bps, drop rate 0 bps Match: any Queueing Output Queue: Conversation 266 Bandwidth 10 (%) Bandwidth 307 (kbps) (pkts matched/bytes matched) 38821117/41198044077 (depth/total drops/no-buffer drops) 23/451018/0 exponential weight: 9 mean queue depth: 12 dscp Transmitted Random drop Tail drop Minimum Maximum Mark pkts/bytes pkts/bytes pkts/bytes thresh thresh prob af11 0/0 0/0 0/0 32 40 1/10 af12 0/0 0/0 0/0 28 40 1/10 af13 0/0 0/0 0/0 24 40 1/10 af21 29061/37806714 422/622400 127/179946 32 40 1/10 af22 0/0 0/0 0/0 28 40 1/10 af23 38418/20436271 9/3544 0/0 24 40 1/10 af31 0/0 0/0 0/0 32 40 1/10 af32 0/0 0/0 0/0 28 40 1/10 af33 0/0 0/0 0/0 24 40 1/10 af41 0/0 0/0 0/0 32 40 1/10 af42 0/0 0/0 0/0 28 40 1/10 af43 0/0 0/0 0/0 24 40 1/10 cs1 0/0 0/0 0/0 22 40 1/10 cs2 0/0 0/0 0/0 24 40 1/10 cs3 0/0 0/0 0/0 26 40 1/10 cs4 0/0 0/0 0/0 28 40 1/10 cs5 0/0 0/0 0/0 30 40 1/10 cs6 0/0 0/0 0/0 32 40 1/10 cs7 0/0 0/0 0/0 34 40 1/10 ef 0/0 0/0 0/0 36 40 1/10 rsvp 0/0 0/0 0/0 36 40 1/10default 69737343/53072240740 388943/477184319 61517/78097195 20 40 1/10
I'm afraid you are going to have to ask the person responsible for your CBQoS config to confirm that your CBQoS policies were applied to the interfaces you require. As a general rule, we are not able to assist with your specific CBQoS configuration.
I am that person. The output I posted is just proof that there is a CBQoS applied to an interface and NTA does not pick it up. May be a bug on your side since I can browse the CISCO CBQOS MIB and see all the information (Bit rate, drops, policy names, class-maps, etc) for the Interface that NTA is not showing.
In that case, your next step would be to open a technical support ticket and reference this thwack post, so we can look at your environment.
In order to receive technical support, you will need to be current on your SolarWinds maintenance. Complete the form. You will not be able to upload your Orion diagnostics, but you will receive an email back that allows you to upload diagnostics.
If we weren't demoing NTA, I would. But, the question over QoS working in NTA becomes a factor in determining a Netflow collector to purchase.
That is not an issue we have run into before. If you open a ticket we can help you get this solved.
pryo--
Don't worry about opening a support ticket. I'm going to get a sales engineer to contact you to address the issue.
M
I've had a little bit of luck removing the policy map from an interface and re-applying it.
Could be a re-indexing issue. Do you have commands for MIB persistence in the config?
snmp-server ifindex persist
snmp mib persist cbqos
Wouldn't that just preserve index for re-boots?
I'm not sure if it is limited to reboots or not.
