OS Info.
This query will pull the information you need for your report only information about nodes that are not ESX hosts:
select N.Caption as [Node],Count(N.AssetInventory.Processor.Name) as [Total CPU Sockets],Sum(N.AssetInventory.Processor.NumberOfCores) as [Total CPU Cores],Max(N.AssetInventory.Processor.Manufacturer) as [CPU Vendor],Sum(N.AssetInventory.Processor.NumberOfCores)/Count(N.AssetInventory.Processor.Name) as [CPU Cores Per Socket]from Orion.Nodes NWHERE N.VirtualMachine.VirtualMachineID is NULLGroup By N.CaptionHAVING Count(N.AssetInventory.Processor.Name) > 0ORDER BY N.Caption
Hi M-Milligan,
Really fantastic. Thank you so much for your valuable answers. Its working.
ESXi (VMware) devices details are not showing/missing. can you please have a look and do the needful.
Report Description:
Please create a report that includes the number of CPU sockets, CPU Cores per Socket, CPU Vendor, Total CPU Cores. This should target all physical servers (Windows, Linux, Solaris, ESXi, Nutanix, Xen).
Ah, I forgot that CPU, etc for ESX hosts is in Orion.VIM.Hosts, not Orion.Nodes. Try this:
SELECT [Node], [Total CPU Sockets], [Total CPU Cores], [CPU Vendor], [CPU Cores Per Socket]FROM(select N.Caption as [Node], Count(N.AssetInventory.Processor.Name) as [Total CPU Sockets], Sum(N.AssetInventory.Processor.NumberOfCores) as [Total CPU Cores], Max(N.AssetInventory.Processor.Manufacturer) as [CPU Vendor], Sum(N.AssetInventory.Processor.NumberOfCores)/Count(N.AssetInventory.Processor.Name) as [CPU Cores Per Socket] from Orion.Nodes N WHERE N.VirtualMachine.VirtualMachineID is NULL Group By N.Caption HAVING Count(N.AssetInventory.Processor.Name) > 0 UNION(SELECT H.HostName as [Node],H.CpuPkgCount as [Total CPU Sockets],H.CpuCoreCount as [Total CPU Cores],H.ProcessorType as [CPU Vendor],H.CpuCoreCount/CpuPkgCount as [CPU Cores Per Socket] FROM Orion.VIM.Hosts H)) AS PhysicalORDER BY Physical.Node
This will select any ESX hosts and any nodes that do not have a counterpart in Orion.VIM.VirtualMachines.
Greetings!
Thank you so much for prompt response. Yes, It is working well.
Is it possible to get the OS on the report for easy sorting?
Sure. Refer to Node.AssetInventory.ServerInformation.OperatingSystem and Node.AssetInventory.ServerInformation.OSVersion, like this:
SELECT [Node], [OS], [OS Version], [Total CPU Sockets], [Total CPU Cores], [CPU Vendor], [CPU Cores Per Socket] FROM (select N.Caption as [Node], Max(N.AssetInventory.ServerInformation.OperatingSystem) as [OS],Max(N.AssetInventory.ServerInformation.OSVersion) as [OS Version],Count(N.AssetInventory.Processor.Name) as [Total CPU Sockets], Sum(N.AssetInventory.Processor.NumberOfCores) as [Total CPU Cores], Max(N.AssetInventory.Processor.Manufacturer) as [CPU Vendor], Sum(N.AssetInventory.Processor.NumberOfCores)/Count(N.AssetInventory.Processor.Name) as [CPU Cores Per Socket] from Orion.Nodes N WHERE N.VirtualMachine.VirtualMachineID is NULL Group By N.Caption HAVING Count(N.AssetInventory.Processor.Name) > 0 UNION ( SELECT H.HostName as [Node], H.Node.AssetInventory.ServerInformation.OperatingSystem as [OS],H.Node.AssetInventory.ServerInformation.OSVersion as [OS Version],H.CpuPkgCount as [Total CPU Sockets], H.CpuCoreCount as [Total CPU Cores], H.ProcessorType as [CPU Vendor], H.CpuCoreCount/CpuPkgCount as [CPU Cores Per Socket] FROM Orion.VIM.Hosts H ) ) AS Physical ORDER BY Physical.Node
Excellent! Thank you so much for the splendid support. Looks like few nodes OS information is not showing is there any issue behind that?
Interesting. How are you monitoring those servers? Are you using SNMP, ICMP, the Agent, or are you monitoring them through vCenter? On my report, the OS is empty under these conditions:
ESX hosts run VMware's proprietary pseudo-operating system, ESXi. If you want to force the OS to be 'VMware ESXi' for these hosts, use this query:
SELECT [Node], [OS], [OS Version], [Total CPU Sockets], [Total CPU Cores], [CPU Vendor], [CPU Cores Per Socket] FROM (select N.Caption as [Node], Max(N.AssetInventory.ServerInformation.OperatingSystem) as [OS], Max(N.AssetInventory.ServerInformation.OSVersion) as [OS Version], Count(N.AssetInventory.Processor.Name) as [Total CPU Sockets], Sum(N.AssetInventory.Processor.NumberOfCores) as [Total CPU Cores], Max(N.AssetInventory.Processor.Manufacturer) as [CPU Vendor], Sum(N.AssetInventory.Processor.NumberOfCores)/Count(N.AssetInventory.Processor.Name) as [CPU Cores Per Socket] from Orion.Nodes N WHERE N.VirtualMachine.VirtualMachineID is NULL Group By N.Caption HAVING Count(N.AssetInventory.Processor.Name) > 0 UNION ( SELECT H.HostName as [Node], CASE WHEN H.Node.AssetInventory.ServerInformation.OperatingSystem is not NULL THEN H.Node.AssetInventory.ServerInformation.OperatingSystem ELSE 'WMware ESXi'END as [OS], CASE WHEN H.Node.AssetInventory.ServerInformation.OSVersion is not null THEN H.Node.AssetInventory.ServerInformation.OSVersion ELSE 'unknown'END as [OS Version], H.CpuPkgCount as [Total CPU Sockets], H.CpuCoreCount as [Total CPU Cores], H.ProcessorType as [CPU Vendor], H.CpuCoreCount/CpuPkgCount as [CPU Cores Per Socket] FROM Orion.VIM.Hosts H ) ) AS Physical ORDER BY Physical.Node
thank you for your response.
Yes, we are monitoring servers via snmpv2c only we are about to move on agent polling soon across Unix categories servers.
bwaccpblade006- monitoring via snmp2vc -Machine Type - Suse (hp).
And also checked few nodes CPU cores per socket & Total CPU cores are missing for dew nodes.
What do you see if you look at the detail page for those nodes? Is there an Asset Inventory page for those nodes? Does the number of CPU cores appear there?
How would I edit this wonderful query to only show me physical servers?
The query, as-is, should only show physical servers. It looks for nodes that don't have a virtual machine ID linking them to the table of VMs, and it shows ESX hosts, which are physical servers.
I had thought it worked that way, My team was trying to tell me that it grabbed vm's.
Sorry about the confusion.
No problem. Can they show you a VM that's being picked up by the query? If it's really happening, I can help figure out why .
