New! v.1.01 Advansed Syslog search, Syslog Parser like Cisco Works, Advanced Syslog Summary and Syslog Counts
Comments?
Gob
Looks good from the screen shot but I'm not sure where to place the files or where to put the block of code that you mention in the TXT I don't have an Orion foler off the Solarwinds Inetpub folder, do I have to creat the folder and legacy file?
Jon
This is great work Gob! I really like it. It is a bit rough around the edges, but it is something that I am able to take and get working easily.
NO! You must find Your Oion website folder!
I think it might help if you specify which version(s) this works with. I don't think the Orion folder appeared until lately (8.5 I think?). These resources work for me running Orion 8.5.1.
I have installed it and got great feedback from my (webconsole) users.Thanks for the effort!!Greetings,
This looks great, but I do get an error
SQL Open Error: Invalid column name 'access'.
I get this when I click on the 'who' link
[quote user="Malvado"]SQL Open Error: Invalid column name 'access'.How to fix it.1. Open syslog_who.asp in any text editor.2. Find and delete ",nodes.access" in two places.BeforeSysLog.IP, Nodes.Caption, Nodes.NodeID,nodes.access, SysLog.MessageType,AfterSysLog.IP, Nodes.Caption, Nodes.NodeID, SysLog.MessageType,[/quote]
That works a treat in v8.1.
Nice!I like it - a few minor issues I seem to be having -The syslog search resource doesnt seem to work - I just get a blank IE page appear with no content at all - not even an error msg. I get the same when I try to use either the "msg" or "summ" links in Advanced Syslog Parser and also if I try to change the Time Period to minute/hour/day etc.But the links to the servernames and the syslog message (where it displays as a number) works, as does the Advanced Syslog summary.Any ideas?Thanks for creating a great resource btw - very useful already!
BTW I'm running this on v8.5.1 SP2
Hi.Have You Header in syslog_search_action.asp (Syslog search results for "traceback" pattern.)Try to run it directly with your message pattern. Have You syslog messages with this pattern in selected period?my_solarwinds_server/.../syslog_search_action.aspHave You error 404 (The page cannot be found)?>Try to view C:\Inetpub\SolarWinds\OrionWeb.logHave You any error with my files? Access error? Not found error?!!!! Have You table ACCESS in your NODES tables?
If You do not have ACCESS table You must remove "nodes.access" from any of my files!Nodes.acces is an undocument feature Try run sql query directly in ReportWriter or MS SQL Management Studio.
This source sql query from syslog_search_action.aspSELECT SysLog.IP, Nodes.Caption, Nodes.NodeID,nodes.access, SysLog.MessageType,syslogseverity, COUNT(*) AS totalFROM SysLog inner JOIN Nodes on SysLog.IP=nodes.ip_address--Add here your message pattern---------------WHERE syslog.message like '%protocol%'--Add here your period (minute,hour,day,week,month)---------------and (SysLog.DateTime >dateadd(hour,-1,getdate()))
GROUP BY SysLog.IP, Nodes.Caption, Nodes.NodeID,nodes.access, SysLog.MessageType,SysLog.syslogseverityorder by total descThis source from syslog_by_msg.asp
SELECT MessageType,syslogseverity, Count(*) As Total,caption, (select nodes.nodeID from nodes where nodes.ip_address='10.10.10.10') as NodeIDFROM SysLog left join nodes on (syslog.ip=nodes.ip_address)Where (SysLog.DateTime >dateadd(day,-1,getdate()))And (SysLog.IP='10.10.10.10')AND(SysLog.Acknowledged=0)GROUP BY MessageType,syslogseverity,caption Order By syslogseverity
This source sql query from syslog_parser_simple.asp
select caption,NodeID,IP, syslogseverity, cnt = count(*)from syslog left join nodes on (nodes.ip_address=syslog.ip)where ip='10.10.10.10' and(SysLog.DateTime >(DateAdd(>hour,-1, GetDate())) )group by caption,NodeID,IP, syslogseverity order by syslogseverity desc
Any results?
Do i have to restart the Solarwinds Website after making these chances to see the outcome.. and it would all be visible under the syslog tab right..
No. No.
You do not need to restart Website, You just add a new resourses. See page 112 on OrionAdministratorGuide.pdf.
Point 5. If you want to add a resource, repeat the following steps for each resourcethat you want to add:
Like i mentioned before our network pro's are enthusiastic about this feature.They asked me if something similar is possible available with Traps (The parser).Any suggestion for me in terms of already discussed or available.Thanks in advance for info.Gerjan
Advanced syslog parser v.1.01 Small bugfix, added custom period for each resource, added SyslogMessagesRate chart.
I feel a little bit like an idiot, but I can't seem to find the Syslog Message Rate graph that you have pictured in your screenshot. Any idea what I might be doing wrong?
This looks great, but I am having trouble adding the SyslogMessagesRate Chart.
Any Ideas.
How do you add the search for syslog tab? i got everything else to work...
#1 Admin
#2 Customize Menu Bars
#3 Choose a Tool Bar to modify and click "Edit"
#4 Click the "+" to add a menu item
#5 At the bottom click "Add Custom Menu Item"
#6 In the "Name" field give your new menu bar option a name. e.g. (Syslog Summary)
#7 In the URL field enter the relative path to you new customized view. e.g. (/Orion/SummaryView.aspx?ViewID=##) Where ## is the ViewID of your custom view. This can usually be found by opening the custom view using the preview button.
#8 Click submit
I dont see the search aspx anywhere.. i checked and i see it in the right folder.. cant put the url in until i find it... any ideas?
I apologize I gave you directions on how to add Syslog Summary to your menu bar. If you are looking for the syslog search "Add Resource" - "Summary Reports" - "Search for Syslog"
I am unable to get the Syslog Message rate to display. It does not appear to be available in my web console.
This is an awesome addition, great work!
I saw in one of your screen shots you had some options for how long each node/interface was down and summaries for each. I am not seeing those 4 options for some reason, everything else is working great though. Any idea what I missed?
It's a separate resource, I'll post it on a Monday. Today, You can use a previous version from here. You must use only this files
You must do the following steps.
1. Copy the Syslog-NetPerfMon.charts file intoc:\Program Files\Solarwinds\Orion
2. In Your console add a new resource. Admin--Customize views--select your Syslog parser page--Edit--click + (add new resources) , click+ on Network Wide Summary Charts, in expanded list select Custom Network Wide Chart, add
3. Preview, in Custom Network Wide Chart click Edit Resourse button. In expanded list select Syslog Messages rate
I have followed all of the steps above and I can't for the life of me get the syslog rate to show in the Custom Network Wide Chart drop down.
May Orion v9 sp1 use it?
Chart still does not work in V9.0 SP2
There's a second piece that was needed to be changed as this was user generated content. We let the user know they should update their stuff. They've posted an update for it.
I don't expect the Dev Team to fix this, and my brain isn't in SQL mode today for some reason...
No go on the "fix" (new error)
System.Xml.XmlException: Name cannot begin with the '=' character, hexadecimal value 0x3D. Line 19, position 48. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args) at System.Xml.XmlTextReaderImpl.Throw(Int32 pos, String res, String[] args) at System.Xml.XmlTextReaderImpl.ParseQName(Boolean isQName, Int32 startOffset, Int32& colonPos) at System.Xml.XmlTextReaderImpl.ParseElement() at System.Xml.XmlTextReaderImpl.ParseElementContent() at System.Xml.XmlTextReaderImpl.Read() at System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace) at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc) at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace) at System.Xml.XmlDocument.Load(XmlReader reader) at System.Xml.XmlDocument.Load(String filename) at SolarWinds.Orion.Web.Charting.ChartXMLConfigManager.GetChartSelection(String netObject) at EditCustomNetworkChart.Page_Load(Object sender, EventArgs e) at System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
The expected chart is "nice to have", but really not required...
Gob, have you re-worked it?
If you recieve any error with my chart you can (must) redownload it and replace the Syslog-NetPerfMon.charts file!
Thanks casey.schmit fot the help. He resolved this bug.
Gob,
Did you have upload the new file?
I have re-downloaded "Syslog-NetPerfMon.charts", but the modified date still is "2008-2-21 16:04".
Please double check and advise.
I placed corrected file. Filename must be syslog_parser-1.0.1_d.zip
CRC32 of Syslog-NetPerfMon.charts must be 822DF7D4
Gob,.. you're custom works are incredible to say the least. However, I am having a problem with this one. I have created a new view called advanced Syslog. Under "Manage Views", I created this, and added the resource's that you described. (Advanced Syslog Summary, Syslog counts, Adv. Syslog Parser, etc.)
When I preview it,.. it looks great. I then go into Customize Menu Bars, and cannot find anything related to the syslog views I created?
I go to edit,.. add,... but I see nothing new?
Anyone else run into this?
IM getting this error:
any ideas,.. I am by no means a SQL guy.
System.Data.SqlClient.SqlException: Error converting data type varchar to numeric. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) at System.Data.SqlClient.SqlDataReader.HasMoreRows() at System.Data.SqlClient.SqlDataReader.ReadInternal(Boolean setTimeout) at System.Data.SqlClient.SqlDataReader.Read() at System.Data.Common.DataAdapter.FillLoadDataRow(SchemaMapping mapping) at System.Data.Common.DataAdapter.FillFromReader(DataSet dataset, DataTable datatable, String srcTable, DataReaderContainer dataReader, Int32 startRecord, Int32 maxRecords, DataColumn parentChapterColumn, Object parentChapterValue) at System.Data.Common.DataAdapter.Fill(DataTable[] dataTables, IDataReader dataReader, Int32 startRecord, Int32 maxRecords) at System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset, DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) at System.Data.Common.DbDataAdapter.Fill(DataTable[] dataTables, Int32 startRecord, Int32 maxRecords, IDbCommand command, CommandBehavior behavior) at System.Data.Common.DbDataAdapter.Fill(DataTable dataTable) at SolarWinds.Orion.Common.SqlHelper.ExecuteDataTable(SqlCommand command, DataTable dataTable) at SolarWinds.Orion.Common.SqlHelper.ExecuteDataTable(SqlCommand command) at SolarWinds.Orion.Web.Charting.NPMChartInfo.LoadData() at SolarWinds.Orion.Web.GraphResource.CreateChart(CustomPoller customPoller, String netObjectID, String chartName, Control parentControl) at SolarWinds.Orion.Web.SummaryGraphResource.CreateChart(String chartName, Control parentControl) at CustomNetworkChart.OnInit(EventArgs e) at System.Web.UI.Control.InitRecursive(Control namingContainer) at System.Web.UI.Control.AddedControl(Control control, Int32 index) at System.Web.UI.ControlCollection.Add(Control child) at Orion_ResourceContainer.ResourcePlaceHolder_DataBind(Object sender, EventArgs e) at System.Web.UI.Control.OnDataBinding(EventArgs e) at System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) at System.Web.UI.Control.DataBind() at System.Web.UI.Control.DataBindChildren() at System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) at System.Web.UI.Control.DataBind() at System.Web.UI.WebControls.Repeater.CreateItem(Int32 itemIndex, ListItemType itemType, Boolean dataBind, Object dataItem) at System.Web.UI.WebControls.Repeater.CreateControlHierarchy(Boolean useDataSource) at System.Web.UI.WebControls.Repeater.OnDataBinding(EventArgs e) at System.Web.UI.WebControls.Repeater.DataBind() at System.Web.UI.Control.DataBindChildren() at System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) at System.Web.UI.Control.DataBind() at System.Web.UI.Control.DataBindChildren() at System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) at System.Web.UI.Control.DataBind() at Orion_ResourceContainer.DataBind() at Orion_SummaryView.OnInit(EventArgs e) at System.Web.UI.Control.InitRecursive(Control namingContainer) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Yes,yes Click Preview and copy URL to clipboard. Then
adminCustomize Menu Barsselect your bar, e.g. "Admin Menu Bar" and click EditClick "+" (Add Menu Item)Add Custom menu itemAdd Name, Description and stored URL
URL must be without address and port e.g. /Orion/SummaryView.aspx?viewid=13
Second questionYou must redoanload and reinstall the Syslog-NetPerfMon.charts file. CRC32 of Syslog-NetPerfMon.charts must be 822DF7D4
Thanks for the tips!!! I copied the URL from my preview page, and pasted it into a custom menu bar and it now displays properly. It does not seem to be incimenting though. Everything is still all zeros, and we have had lots of syslog events in the meantime.
The chart is still an issue. I just downloaded your custom piece today, and you are saying I need to download it again to get Syslog-Netprfmon-charts?
This may be a stupid question,.. but how do I check the CRC32? I know crc is a redundancy check, but not sure where I would find that info?
Thanks again.
I have downloaded syslog_parser-1.0.1_d.zip several times. The CRC on the Chart file is still 3B8618B4. Any one else not able to see this new CRC value?
Boy,.. im begining to think I am highjacking this thread. Anyway, I have this new view working and am in awe of GOBs custom works. They are great! Everything is working great except for 2 issues. I can not get the chart to work,.. the CRC on the file that I downloaded today is differant than the CRC that GOB says is needed. Anyone know whats up with that?
Second issue is an invalid column access. I have deleted the 2 enties in the Syslog_who.asp file and I no longer get the invalid column when click on the "who" section of the table. But I do get the error when attempting to search using the Search for Syslog. Anyone know whats up with that?
Orion - 9.0 SP2 - 1,500 elements.
NTA
Cirrus
APM
I hijacked it last week...
I gave up on the chart, nice but not required, some days it works others it doesn't
add a custom property named access to your nodes table
Maybe you can try Orion v9.0 SP2, it's works fine!
I'm taking a look at installing this (v9.1 sp1) and have a couple of questions:
thanks!!!
Hi, I copied the files to the respective locations but I'm having problems. I get the error SQL Open Error: Invalid column name 'access'. So I modified the syslog_who.asp file and removed 4 instances of nodes.access and I still get the error. I also don't see any graph either. Does anyone have any ideas?
I have Orion version 9 and was trying to get this to work but having some problems. Does anyone have some detailed instructions on how to install?
on my page I get errors:
And all the colums say nothing, msg, summ and 0
Thanks for any help
Robert
my page I get errors:SQL Open Error: Invalid column name 'access'.
Just create empty Access table.
Run Custom Property Editor. Then press Nodes,Add,Build a Custom Property from scratch, Add to Nodes, Name - Access, Type - text, length - 10You can fill it later. SSH and Telnet url is very nice and useful feature!
Sweet, worked Great! Thank you very much!!!
Well when I try and build the page and when I look at it this is what I am getting
Execute this query via ReportWriter
select syslogseverity, count(*) from syslog where (SysLog.DateTime >dateadd(month,-1,getdate()))group by syslogseverity order by syslogseverity desc
select syslogseverity, count(*)from syslogwhere (SysLog.DateTime >dateadd(month,-1,getdate()))group by syslogseverity order by syslogseverity desc
and do get data returned. Could it be the way i have the view setup? I created a custom menu item, but used the link shown in the "Preview" window when i created the view space.
Short of this, EVERYTHING worked perfectly w/o a hitch, even the charts.
Thanks for an awsome addon!
I am on 9.1 sp5 and my syslog chart works but the actual parser function does not show on the page. It worked fine for years until we had to do a new install and removed a piece of the program. Any ideas where where to start since I keep going down the wrong rabbit hole?
If you move to 9.5 we moved this functionality in out of the box. If you had this on 9.1, you will need to download the resource GOB wrote on the thwack context exchange
Yeah I know about 9.5 and the functionality, I am looking forward to using it. The change in architecture caused a delay in our upgrade as we are on a shared SQL server and our DBAs could not give us the access we need. We should get our stand alone SQL server in August. This should help the response time of the program as well. I was just trying to find a work around until then. I will just keep hacking away til then.
Thank for the help.
