I want to create a fileshare monitor...
For now I have used a file existance monitor for "\\${IP}\User$\*" but this fails if there is no file in that share (only folders).
What would be the best way to just check if the fileshare is alive?!?
You can still use VB script for this. It can be a short one, something like:
strFolder = "\\computer\share"set objFSO = createobject("Scripting.FileSystemObject")if objFSO.FolderExists(strFolder) then wscript.echo "Message: The folder exists" wscript.echo "Statistic: 1"else wscript.echo "Message: The folder does not exists" wscript.echo "Statistic: 0"end if
i am not sure this is exactly what you are looking for but it seems you could use APM's WMI to monitor this:
select * from Win32_Share
and then there are Instance Properties where one is called "STATUS" - all of mine show "OK"
but perhaps you could use this to build your logic where Status<>OK
...good luck.
do you have a template for this that you can share?
i don't
but i can try to build one and do a proof-of-concept for you
here are the steps to making this.
i created a share named SW$ on a server.
i used Create New Template on APM and selected to use WMI MONITOR.
in the field for WQL QUERY i used Select STATUS From Win32_Share WHERE Name = 'SW$'
i assigned this to that server. it went GREEN in APM and all is well.
i created an alert to monitor the Component Name i used for this: TEST - WMI Monitor SHARE named SW$
the alert condition was for the Component Status and the alert action was an email.
i went to the server and removed the share name and later got the email alert. it was alerted as being 'unknown' status but this would be same as fileshare failure.
i hope this helps...good luck.
thanks, unknown wont work for us but i'll try to figure something out to make it go critical or down and of course try the implementation you suggested.
i did not do this, but if you change the Warning and Critical to perhaps 0 and 1 - i think it will avoid the unknown otherwise APM does this expresses it as NO RESULTS WERE RETURNED BY WMI QUERY - and this is really annoying.
no, if the share does not exist, the wmi query will actually not return any results so i will have to leave out the where/filter part and then maybe make a loop to check all elements for "SW$" and return 0 or 1 if found/not found... just dont know how the syntax will look like for that...
Then you would have to use script for that. Unfortunately WQL language doesn't support such things as looping.
hrmpf :-\
why cant there just be a directory existence monitor? :P
i couldnt find anything like that shared already in thwack either
is there something similar i can use as a base where only minor adjustments need to be made? :P
Found this script which works great but how can i configure alerting on this? The node always stays up and just the message changes.
Hello,just set threshold for statistic to "less than 1" so component will have warning/critical status which you can use for alerting.
Or you can add:
WScript.Quit(0) to the end of first condition and WScript.Quit(1) to the end of second condition and then your component will have Up/Down status.
works great!!!!!!! Thanks
