we have installed a solarwinds
but i am not sure if i should expect this system to monitor SQLSERVER instances.
could someone with experience on this give some guidelines on how to install or explain what is missing ?
thanks,
This helps a ton. First you need to ensure that in your main Summary screen under the Home tab or through Manage Nodes that your SQL server is being monitored. If it is, and you are monitoring it via WMI, then do a list resources on the device. It should then show the AppInsight for SQL and the instances you can monitor. If the node isn't managed, then add the node (recommended using WMI) and during the add process the AppInsight should be shown as an option.
Regards,
Matthew Harvey
Loop 1 Systems
What did you install? Did you install SAM, NPM, or the Database Performance Analyzer for SQL (formerly Confio Ignite)? If you did not install and setup either SAM (Server and Application Monitor) or the Database Performance Analyzer for SQL, then you won't get SQL isntance monitoring. If you did, then you'd need to have access to the instance via either Windows or SQL authentication along with adding the server and SQL instance to be monitored.
Senior Sales Engineer
i am not sure
but it seems to the the version of your product that monitors VMWARE.
i have access to all manners of measures on the VMs.
so would it be possible to bolt on an 'extension'
or
is this a case of purchasing a new product at a massive discount - as an existing client?
nicolas diogo, I'm not really clear on your question. It does seem that you are talking about Database Performance Analyzer (formerly Confio Ignite). DPA has an optional feature that requires an additional license. This feature enables DPA to juxtapose database performance data with VMware events so you can more easily make a case whether or not a database performance problem can be attributed to things like noisy neighbors (resource hungry VMs on the same host). It is a very popular feature for IT pros facing the virtualization of their database environments, especially if their VMware admin is too quick to say, "not a VMware problem" and won't allow access to VMware data critical to performance troubleshooting.
hi Brian
i think the keyword of your answer is 'juxtapose'
i am not That certain which product version we have installed here.
is there a way of identifying it from the user screen.
i was trying to do that by adding the footer that i found on my webpage/screen
and that is why i have added:
solarwinds Orion Patform 2014.1.0
but now it seems this info is not descriptive enough to allow for an identification.
any suggestions on how i can identify our product?
Oh. Maybe you don't have DPA installed then, b/c of the way you're saying Orion Platform 2014.1.0. That is not a DPA version number. So if you are interested in a deeper dive into DPA, I can have an SE follow up with you. Would you like me to do that?
yes please
i will be back tomorrow morning to carry on with the tests that we are conducting.
i am based in London.
and i believe my phone is on the profile.
if you let me know what details you would require from the client to assert which license they have.
i will try to have those on hand by the time we discuss this further.
is that a good way forward?
If you only have the Orion Platform, than likely you are referring to Orion NPM or SAM (this can be seen in the footer of the web front end. Of those products, only SAM can do SQL instance monitoring, but requires WMI, SQL, and RPC access to the instance.
?? Not sure what you were replying with, nothing seems to be showing up.
i replied by email
the system accepts the email - but fails to parse it.. here is the message
below is the whole footer as it appears on the page.
SolarWinds <http://www.solarwinds.com/> Orion Platform 2014.1.0, SAM 6.1.1, IPAM 4.1, NCM 7.3, NPM 10.7, NTA 4.0.1, Storage 5.1.0, IVIM 1.9.0, VNQM 4.1 1995-2014 SolarWinds Worldwide, LLC. All Rights Reserved.
does it help?
well, i have no idea how i did it but ...
i have clicked on a tab named 'applications'
and i have found, a sub-menu,
and an entry named 'SQL Server'
it seems to contain servers on our network
a few appear to be monitored..
but not the server that i am interested - that is always the way!
how do i add this server to be monitored? it seems that i should look for documentation on this.
what should i look for?
any suggestion?!
OK
just bought a sandwich - it is 8pm London now.
let me try and follow you.
found the Summary > Managed Nodes
and i can not find the Server,
it had firewall enabled and blocking WMI
i have disabled it for now - to test.
how do i add this server to the list?
thanks!
