Hello,
I was wondering if anyone knew how to set up something to automatically export CSV files through the Report writer.
Thank you in advance for any advice you have.
Regards,
-Dustin
Sounds like you have this set up to send as an html format report. Have you tried changing this to pdf? It may be that your email client is limiting the preview of the email. Are you using outlook?
Also make sure "Group historical report by days" is not checked on the general tab of the report in report writer.
Sent from my iPad
When/how do you want to get this CSV output?
If you want it ad-hoc, as in "I click the report in the Solarwinds portal and I get CSV instead of on-screen data", then you can add "&dataformat=excel" to the end of the report URL,
If you want the CSV delivered to you via email (a la the report scheduler) then the only way I've found is to mimic the SQL and set up a scheduled job to email you straight from the database itself (ie: set it up in SQL Management Studio).
I tried adding the "&dataformat=excel" to the URL but it is not working for me.
Now when I get the emails everything is blank and at the bottom it says Enable Javascript to login.
Do you have any idea's on how to get around this?
Have you tired '&dataformat=xls" ?
The list of usable formats I have are:
txt
xls
csv
jpg
raw
xml
Know of any others?
Thanks for the tips.
Now I am having a different issue. When I run the report they continually say at the bottom " Enable Javascript to login"
I have went through IE and tried turning on every setting I could think of but I keep getting that message.
Anyone have Idea's on how to fix that?
Thanks again,
Have you tried the following to enable jave in IE?
Hi dkeyser,
I have tried what you suggested and I get the same thing.
When I browse to our solarwinds page in IE I am able to get there fine and see everything.
It is just when I run the reports that is says enable javascript to login.
Thanks again for your help
I'm unable to reproduce any results like the ones you've mentioned. It sounds like your browser is having trouble opening the webpage. Are you sending the login credentials using the report writer?
Maybe try clearing cookies and cache to see if something was stuck.
Hmm, I made a new report and instead of using a service account we created I ran the report using my AD credentials and it worked
Now, I have another issue with the reports.
When I look at the reports on the web I only get 5 or 6 lines, but when I execute the query in the report writer I get about 2000 lines.
Do you know why that is?
Thanks again for all your help
What format are you sending the report?
I have tried sending it as a csv file and as an xls file.
When I put the &dataformat=xls or &dataformat=csv at the end of the URL the report will not email out.
If I take those things off the end of the URL the report will send but I only get 5 or 6 lines.
Thank you,
THANK YOU SOOOO much dkeyser, your suggestion of unchecking "group historical report by days" worked and now I can see all the data from the report on the website.
I just tried changing the report to pdf in the report scheduler but it is still not getting sent out for some reason.
Thanks for all your help
Never mind!!! the report just came through and it did it is CSV format problem solved
Thanks again!!!
Excellent!I still can't get mine to send an email with the csv format. Congrats! You should do a write up on how you did it so others can benefit.
Thanks again for everything and I just have one more issue with the report.
I got the CSV to sent but when it is send it shows all the fields.
In the report I have hidden fields and when I look at the report on the Orion website, the hidden fields don't show up, but in the exported CSV file they do.
Do you have any idea what would cause that or how to fix that?
Going back through my testing I've come to the conclusion that the columns you hide in the web console are hidden because of the flag given to them in the writer. That flag is ignored when generating the CSV. You would have to remove those columns from the report in order to remove them from the CSV file. I hope that helps.
ok, thanks for the info
Can you please show how you configured the Report Scheduler to email you the CSV files? I have not been able to get this working in all my tests and whenever this has come up with SolarWinds (thwack/support), they have said it is only possible to schedule PDF or HTML reports - not CSV, XLS, etc.
Edit: I have just seen your post here regarding the steps: However, as per all my previous attempts this still does not work? More details within that thread.
thwack.solarwinds.com/.../DOC-169128
This is his write up.
Yep - saw that after my post hence the edit (it links to his write up). Didn't work. :-/
I'm in the same boat. Awesome that his works but it does make me curious what is different between our setups that makes the difference. Would be a nice addition if SolarWinds would add that functionality to its report scheduler. Would make automation easier.
