Is there a date for when IPv6 will be supported in Orion NPM?
Updated in Feb:
We're actively working on it now, for all of our products. You should see advances in this area in 2009.
It's on the list, but nothing I can commit to time frame wise, if you want to see what is actively being worked on see here
Thanks for the list of what you are working on. I welcome the most of the items, but frankly there is no big new feature, deserving a major release (e. g. 10.0). Hint, hint ... ;-)
Hello,
I posted this in a different portion of the forums but it might be more appropriate here:
Can you give us a date yet on when Orion will have IPv6 support? My Engineers are turning up IPv6 soon and are wanting to move my management network into it first. I have a large Orion implementation and have only just begun to look into this.
If this feature is being driven by customer demand then please put me into the "demanding" category. ;-)
Got ya down. Can you tell us more about it though. Are you moving to pure IPv6 or dual stacked?
Certainly! At first, we will be moving into a dual stack implementation. The goal is for native IPv6, though.
I have only started considering this whole deal but it looks like this will affect many things within my Orion implementation. For instance, IPv6 requires netflow v9. v5 no worky. So what does this mean for NTA? Does it already handle v9 flows?
Ugh. Lots to think about.
What is your timeline like? See Andrew's post regarding Netflow v9. Also Toolset and NCM currently support IPv6 as well.
Thanks Andrew! Brandon, our time line is this spring. It is looking like around May is when we will be turning it up.
And which spring would that be?
Any updates on when IPv6 will be supported? My company needs to know and is nearing the point of looking at alternatives to NPM.
See here for what we are working on now.
We are soon to go into beta on some of these features, one of them being IPv6 and if you are interested please let me know. You need to have active maintenance to participate this.
What does being a beta tester for IPv6 entail? Do we have to run a new rev of NPM or is it more like a module/plugin?
Stand up a new VM or server to run the beta on. You leave your current production server alone, we do not support running beta on top of your current production install.
It is basically having another Orion server hitting a portion of your network and you give us feedback, point out the bugs etc. and help us shape and further mold that feature.
