plesase see the attached picture which shows lots of strange error events.
what's this and how to solve this?
any advices will be usefull
thanks a lot
why are you porting this again? or was this a "old forum" re-import?
From the looks of this new screen shot, forgive me if I don't get the language set correctly, but it looks like the DB is set to use English, and the devices are named using an international or Chinese character set. This would explain the ????'s because the device/interface names can not be interpreted.
On the SQL server open the SQL Server Books Online and search for "Collation Options for International Support"; once you get the DB speaking the same language as the devices, then you should get rid of the locking issue and errors reported by the MainTaskDataReader. (hopefully)
these error events disappeared for two days.
and now they appeared again.
after upgrading orion to V8.1, another kinds of strange error events appeared.
After upgrading to 8.1 have you reapplied the "Collation Options for International Support" steps as jtimes suggested?
I could not find search the "Collation Options for International Support" in the SQL Server Books Online.
and I don't know how to get the DB speaking the same language as the device. how to set this ??
http://technet.microsoft.com/en-us/library/ms142796.aspx
these may help-?
Eric-
In response to your issue:Error Opening MainTaskDataReader Timeout expired If you go to C:\Program Files\SolarWinds\Orion> an look for SWNetPerfMon.DB. Open it (you might need to use notepad to open it) then scroll down to the bottom an edit the following:Connection timeout in secondsTimeout==20 Database Command timeout in secondsCommandTimeout=90Change the 20 to 40 change the 90 to 110. You can increase these if you like- however this is just a suggestion.
Mark,Thanks a lot.
The picture is shown on Orion website
Eric,
After I upgraded to 8.1, I have the same errors apearing 2 at the same time every hour. I have a case open with Support - 9272
I just boosted the SWNetPerfMon.DB Timeout settings, so I'll let you know in an hour or so...
6/27/2007 08:54 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 08:54 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 07:54 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 07:54 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 06:54 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 06:54 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 05:54 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 05:54 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 04:53 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 04:53 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 03:53 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 03:53 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 02:53 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 02:53 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 01:53 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 01:53 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 12:53 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 12:53 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared.
Mark,
NO change...
6/27/2007 10:54 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared. 6/27/2007 10:54 AM Error Opening MainTaskDataReader Line 4: Incorrect syntax near ')'. Line 6: Incorrect syntax near ','. Line 7: Incorrect syntax near ')'. Line 10: Incorrect syntax near ')'. Line 12: Incorrect syntax near ','. Line 13: Incorrect syntax near ')'. Statement(s) could not be prepared.
These only show up int the web view, so I the question is what is Orion web server trying to do every 60 minutes involving the MainTaskDataReader? I'm going to shutdown my Hot Standby server to see if at least one of theses goes away...
Edit - no change with the HSB off :-(
Thanks for the info Mark, thats more than I got from Support...
I'll ask my CIO to stop "freaking out" ;-)
Still it would be nice to get them awat since they disturb the nice "Summary view" with red marks Any news to this problem?
Sorry, which problem? What's the issue? Could you post a screenshot?
Hi All,
Thanks for all your help.
And when I upgraded the Orion to V8.5 I found all these strange events did not appear any more.
Thanks.
