Solved.
SolarWinds Alerting Engine wasnt started.
anyone?
I've got a similar problem in that if I try to test an alert it gives me an error message, I've got a call open with support who are looking into the problem.
Jon
As a workaround you can test advanced alerts by using the Advanced Alert Manager. This application is located in advanced features under Solarwinds Orion. Do no test from NPM.
did that. no difference. emails are still not being sent.
I also tried the Test Fire Alerts with no luck.
Is there anything else I can try?
so the alert itself is not working but testing it works in that it shows that it fails? or the Testing of the Alert does not "test"?
Testing the Advance Alerts = nothing
Basic Alerts are working
Test Alerts from Basic Alerts are working.
You shouldn't be able to test Basic alerts in the Advanced Alert Mgr.
Is the adv. alert enabled? Are you getting an hour glass when testing your advanced alert in the Advanced Alerts Manager?
Mark, I'm getting an hour glass when trying to test fire alerts. Sounds like this Is this an known issue. Is there a workaround?
Is the hour glass occurring in the Adv. Alerts Manager?
Yes Sir
Mark, I'm getting an hour glass when trying to test fire alerts. Sounds like this Is this an known issue. Is there a workaround? Is the hour glass occurring in the Adv. Alerts Manager?
For anyone who gets an error message pop up when test firing an advaned alert.
I've been told by SolarWinds support that it should be fixed for the version 8.5 beta.
They probably wanted more info...
I reported it back on June 14th, and managed to tie it down to a regional settings issue.... Setting my Orion server to United States instead of United Kingdom would test fire the alerts OK.
According to the Tier III support guy, the problem was a lot harder to fix that they originally thought, so any extra information from other people such as you would have helped.
I have exactly the same issue as the person in the first post, the difference is that the Solarwinds Alerting Engine is started, I always had configured and enabled 4 advanced alerts and no basic alert, everything was working fine, but all of a sudden I stop receiving the e-mail alerts, then I went to the Advanced Alert Manager and the alerts were enabled but no e-mail in my inbox, then I made a test for one alert and nothing happens, at first seems that the system is trying to trigger the alert, but I got nothing displayed in the log space, even if I refresh, nothing displayed, no e-mail, no hourglass... nothing.
If I make the same test with the Basic Alerts, I get the e-mail correctly, right now I'm working with the Basics, but I need to make the other function properly. btw I'm using
