I have Audiocodes Media Gateway's that I just put in the NPM, although, how do I install the audiocodes MIB's database in Orion to view the specificdetails and/or MIB specific information?
Submit the MIBs in a support ticket. We'll add them to the DB. We update it every week.
but then How do I get them back to add them to NPM?
speaking of updating it every week has anyone automated their Orion server MIBs.cfg update process?
can you explain how to do this?
You could use the built-in FTP tool with Windows in a batch file that will download the file, then extract it.
ftp -s:ftp.cfg -A ftp.solarwinds.net (-s for answer file, -A for anonymous login)
and provide the ftp answer file such as:
get /cmb03/MIB-Database/MIBs.zipquit
Extract the contents with your favorite ZIP tool to the necessary directories.
Then run this as a scheduled task.
HTH
and where are the necessary directory suppose to be?
When you download them from the portal there is a readme included with instructions.
The MIB database is zipped and can be installed by copyingthe new MIB database file (MIBs.cfg) over your old database file.1. Using Windows Explorer, navigate to your installation folderand locate the MIBs.cfg file. By default, this is located in one ofthe following locations:* Cirrus: \Program Files\SolarWinds\Configuration Management* Orion: \Program Files\SolarWinds\Common* Toolset v8: \Program Files\SolarWinds\Engineer's Edition\* Toolset v9: \Program Files\SolarWinds\Engineer's Toolset\2. Unzip the new MIB database to a temporary directory, and thenreplace the outdated MIBs.cfg file with the new MIBs.cfg file.
ok, so now that I have done this part, I have sent a ticket to add Audiocodes MIB tables but where do I send the MIB database?
Also, is there a way to get views of a specific MIB table for a device onto the Orion website?
For example, I have 2 Acme SBC's, and I need to know (from Orion website) the actual number of sessions active on the SBC's.The MIB table I need to see is: 1.3.6.1.4.1.9148.3.2.1.2.1.1.4
You have me confused. You should have submitted them all attached to the support ticket so they can be compiled into the next MIB database update.
Here is an excellent tutorial that explains how to display results on the website-
www.solarwinds.com/.../index.html
When I created that ticket, there is no way to attache files.
When you hit submit you will receive an auto-reply with your case number and you can then attach the files to your case.
Done, thanks alot !
Last question is how do i change the time for the polling of the universal pollers?
Is there a setting somewhere to change the time to poll?
UnDP polling times the same as the statistics polling intervals. You can edit the statistics polling interval for nodes and interfaces in Web Node Management or via System Manager.
Is there a list somewhere that shows all the manaufacturer MIBs that have been added into the MIBs.cfg file in the \ProgramFiles\Solarwinds\Common folder?
