I would also like to know if this is possible.
Thanks.
APM should do that for you. It will monitor the response time to a webserver by sending an HTML 200 request and response.
How would I go about setting that up? Do you know? I have the Application Monitor monitoring various services on various servers, but am not sure how I can set it up to monitor the website. The site is running via IIS.
Check Pages 21 and 22 on this doc.
http://www.solarwinds.com/support/apm/docs/APMAdministratorGuide.pdf
Check Pages 21 and 22 on this doc.http://www.solarwinds.com/support/apm/docs/APMAdministratorGuide.pdf
I was looking at those instructions earlier, and my module is called Application Monitor, not Application Performance Monitor. I cannot see the options that are listed in the Admin Guide. Do I have an old version that does not support this? I am running Application Monitor 8.0.21 with Orion NPM 8.5.
Yep, you have the old version, now they call it APM.
APM is a new product, but all customers who had AM and were current on maintenance were automatically granted a license for APM. If, for some reason, you do not see APM in your customer portal, you should call Customer Service and they'll help you get that fixed.
Thank you for that. I logged into my customer portal and saw the available license. I have installed it and have followed these instructions on how to setup an http monitor. http://www.solarwinds.com/NetPerfMon/SolarWinds/wwhelp/wwhimpl/js/html/wwhelp.htm?context=SolarWinds&file=ApplicationPerformanceMonitorAdministratorGuide.4.21.htm
After I created the Application Template, I am not sure on how to proceed from this point on. Am I supposed to Assign a Node to the Application Template? If so, does that mean the web server that the website is hosted on needs to be added as a monitored Node in Orion NPM?
Yes, after you create an Application Template, you assign it to one or more servers. Once assigned to a server, you've got a live Application, which will show up on the APM home page. The assigned Application is the basic unit for monitoring within APM.
So to monitor a website, do you just put in the url of the web or do you have to be monitoring the server it is running on?
You can monitor the site url itself. You do not have to monitor the server but you do however need to attach the HTTP Monitor to an existing Node. I am still unclear as to the reason for this but I haven't had the time to look it up yet.
What I am doing is this. I run a primary (where NPM,APM, & Netflow run) and 2 secondary pollers. I have set my primary and one of the secondary pollers to check an intrnet website's main login page. I am trying to verify that this setup will provide a real end-user response time picture.
