quote:Originally posted by MithrilhallYou say virtually identical devices; what IOS are you running on the affected device and the identical devices?
quote:Originally posted by nwoodHas anyone reading this experienced CPU spiking (90%+) on a Cisco device as a direct result of regular SNMP polling? Every 5 minutes (to the second), I'm getting a CPU utilization spike on the device to which our NPM server is connected... but not any of the other, virtually identical (as in models, configs, loads, connections, etc) devices.Reading Cisco documentation, it sounds like it's nothing to be concerned about as process prioritization won't allow low-priority stuff to affect routing, etc. I also recognize that there's a difference between how things should work and what's actually going on.If anyone has had experience with this and has found a workaround/fix, I would love to hear about it. Thanks all.
quote:I had what sounds as something very simular. I Upgraded the Orion server to Server 2003. The problem still occurred. For the past week I've been exiting the Orion system managered when I've been finshed with it. I used to just minimize it. It's been better this week. I easiest way to clear the problem was to reboot the Orion server.Brain RiessHamilton, OntarioCanada
quote:Originally posted by nwood quote:I had what sounds as something very simular. I Upgraded the Orion server to Server 2003. The problem still occurred. For the past week I've been exiting the Orion system managered when I've been finshed with it. I used to just minimize it. It's been better this week. I easiest way to clear the problem was to reboot the Orion server.Brain RiessHamilton, OntarioCanada
quote:Originally posted by Network_GuruI only see this on our 4507R's when we enable L3 routing.The CPU does not spike, but the ICMP echo reply latency goes way up.It basically makes the latency graph useless for alerting or troubleshooting the switch.Devices pinged through the switch are fine. NG
quote:Originally posted by Network_GuruNWood, You are correct sir!I just reviewed the CPU utilization on one of my 4507R's with L3 routing enabled & it is indeed spiking up to 80%...-=Cheers=- NG
quote:I am wondering if you got my previous email on when I mentioned that you are hitting an IOS bug and that as fix you would need to upgrade to at least 12.2.31.SGA
Switch-sp1#show process CPU sortCPU utilization for five seconds: 67%/0%; one minute: 60%; five minutes: 59% PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process 30 337225568 717375789 470 59.07% 50.83% 50.81% 0 Cat4k Mgmt LoPri 29 3286933180 419403083 7837 7.27% 7.14% 6.83% 0 Cat4k Mgmt HiPri 72 61954092 327477093 189 0.31% 0.23% 0.23% 0 IGMPSN 115 30345304 178211734 170 0.15% 0.08% 0.09% 0 IGMP Input 57 17071556 132235452 129 0.07% 0.17% 0.08% 0 IP Input 133 9914264 163708621 60 0.07% 0.05% 0.05% 0 cpf_process_ipcQ 24 3270180 305114372 10 0.07% 0.01% 0.00% 0 Net Background 7 0 2 0 0.00% 0.00% 0.00% 0 Timers
quote:Originally posted by Network_GuruWe opened a ticket with Cisco TAC, since one of my 4507Rs has been running at 60% for the past 8 months (thanks for bring this to my attention) & here is their reply: quote:I am wondering if you got my previous email on when I mentioned that you are hitting an IOS bug and that as fix you would need to upgrade to at least 12.2.31.SGA
