Hi there,
I think i am being a little thick on this one, but i can't seem to configure an alert to email me when a server reboots. There is the one out of the box (which sends an alert to the log) when i add an email action and try to save, it tells me to specify a trigger action?
When i look in the trigger actions, there is nothing specified (although it does show in the NPM log)
When trying to set it up from scratch - i select 'type of property to monitor' Node:
Choose trigger alert when all of the following is met:
add a simple condition, click on the * and the only options i have are:
Network Nodes > Current CPU & Memory > memory availble and % memory availble
then polling details > Skipped polling cylces & (Now - Last Sync) in minutes
So not really sure where to locate the reboot monitor.
Any help would be great!
To add to this: if i select volume in the 'type of property to monitor' i get the right options under network nodes (including last boot) but the email doesnt work!
