Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Cirrus and TACACS
danbowen
Hi Everyone,
Has anybody ever got Cirrus to login to a device that is TACACS enabled?
I have tried but with no success. If I remove the TACACS config and simply configure a local username/password and enable then it works fine. But with TACACS, it complains of not being able to login at the enable level.
Any help would be great,
Cheers,
Dan
Find more posts tagged with
Accepted answers
All comments
ceclark
Dan-
If you add 'privilege level 15' under the vty lines, it will login to level 15.
cgeroldinger
Hi Dan!
We run over 200 nodes on Tacacs and Cirrus.
Have you configured the correct Login Information (username and password )in Cirrus? Make sure at Tacacs that this User is allowed to enter the ena mode.
The only problem I had was at Cisco PIX. But fixed that too
Christian
danbowen
Thanks guys but it turned out to be the prompt string.
Cirrus looks for "enable password", but I had my TACACS server setting the prompt to "enable:". Apparently if the two are not identical it doesnt work!
Thanks anyway,
Dan
StephenT
Hi Dan,
Where do I go to change the prompt string within Cirrus?
Ta
Ste
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
