which system administrator are you talking about?
I also noticed the lsass.exe process taking a ton of cpu-time on my orion server sometimes...
There are also some trojans that can cause this to happen... also if it's a DC:
support.microsoft.com/.../842382
Here is a list of malwares that uses lsass.exe http://www.file.net/process/lsass.exe.html So, malware is also a possibility.
i doubt its a virus/trojan and its not a DC.
Virus scanner is installed and nothing but Solarwinds products have ever been installed on the server, internet security is on high and nobody surfs on that computer.
Have you upgraded to APM 3.5 RC? It should be in your portal now.
We just upgraded to ALX on APM, I have added several monitors and now the server is almost constantly at 100%, most of it coming from this lsass.exe process.
Any solution to this?
EDIT:
I opened a ticket with #159443
I was told the solution is to either wait for NPM v10 and upgrade to Win2008 R2 or wait for APM 3.5 to release.
*vents*
Until then... I guess we just have to delay go-live of solarwinds again.
Its only been 7months anyhow... not quite the ~1hour until its ready... and a lot of wasted money for support, if I knew I would have waited a year for the purchase.
*/vents*
The NPMv10 RC3 is about as production ready as it's going to get. I understand companies being afraid of Release Candidates after some of the things that have happened with Microsoft. I'd look at the NPMv10RC3 and W2k8R2 if you require it.
nope, no RCs for us. We will have to wait for v10 to be released
NPM 10.0 and APM 3.5 will GA together very very soon. In fact, I can safely say it doesn't make any sense to wait any more since the last RC build (RC3 for both) IS the GA build. The RC period is over and we're NOT making any more changes before GA.
ok, good...
would you still recommend upgrading (because of the bugs/incompatibilty with APM) from win2008 to win2008 R2 while updating APM and NPM?
I'd recommend upgrading to NPM 10.0 and APM 3.5 at the same time versus just doing the upgrade to NPM 10.0 if that's what you're asking.
I did that... and it seems the cpu load issue got better but I think its still there...
cpu-load isnt always at 100% anymore but the lsass.exe is still taking up a lot of cpu... I just checked and it took up 70% of a quadcore (HP DL380 G6)
