How to install Virtualization Manager in existing Solar Winds server .I already have 8 components s with that how to include this also.
The Virtualization Manager (VMAN) is a prepackaged virtual appliance. It can be deployed to VMware or Hyper-V. Once deployed and assigned an IP address browse to that IP with a web browser.
If Vmware, you'll only add your vCenter server info.
Once that is up then on your SolarWinds Orion web console go to Settings (All Settings) > Virtualization Settings
Inside there run the synchronization wizard.
That should set up the integration and add the Virtualization dashboard
Whether we need to install any agent on vcenter server to communicate ? getting not able to find host error
You don't need to install anything for VMAN to work. You just need to make sure that you are connecting over the correct port (default 443) and that the account you are using has read permissions.
"Unable to connect to the specified address"
Getting the above error. Kindly help.
Can you provide a screenshot?
The IP Address that you are trying to integrate it to, that is the IP address of the virtual appliance of Virtualization Manager, correct?
Yes the IP of vcenter server is correct and i can able to connect to vsphere client
It is the IP address of the VMAN virtual appliance which should be used here.
Install SolarWinds Virtualization Manager
To fully install VMAN, the steps are:
Have you deployed the VMAN appliance .ova file in vCentre?
Deploy Virtualization Manager on VMware vSphere 5.x or later
So I cant integrate with vcenter server ,However many tools cab be directly integrated with vcenter any specific reason ?
I guess you have a different perception what vman can do for you.
vman is just pulling data out of your vCenter and ingesting it into the VMAN-Appliance DB to analyze the data. This ensures that there is no constant load on your vCenter. And guarantees that you can keep the data for as long as you need it.
VMAN Appliance also has a website where you can see information and statistics, the nice thing is, that Orion can pull the data as well from the VMAN-Appliance and display it in the "Orion-formatted" way.
you could use the IVIM (integrated virtual infrastructure manager) if you do not want to deploy the vman appliance. this gives you a limited set of information but it might be sufficient for what you need.
ivim is integrated int NPM as far as I know
hope that clears the confusion
For each vcenter we need to install one VMAN or it can manage multiple.
It can manage multiple.
Thanks ,So VMAN can be deployed in one vcenter server and other vcenter can be integrated ..Kindly confirm ..I have vcenter across geographical locations hope it must not use much bandwidth.
Hi there! I just posted a new VMAN Installation Guide here that can be helpful, especially the Port Requirements post: VMAN Installation Guide - SolarWinds Worldwide, LLC. Help and Support
Also we just released a new VMAN 7.2 appliance today running on CentOS 6! You can't upgrade to it, but must migrate.
Release Notes: VMAN 7.2 Release Notes - SolarWinds Worldwide, LLC. Help and Support
Migration Guide walk-through: VMAN 7.1 to 7.2 appliance migration for CentOS 6 - SolarWinds Worldwide, LLC. Help and Support
Cheers!
Oh and a side note, many folks hit issues with the permissions needed in vCenters/VMware and VMAN.
Never a bad idea to double check accounts and permissions. This info should help on that: Account permission requirements for VMAN - SolarWinds Worldwide, LLC. Help and Support
