Thx! (avatar)
Did open a ticket, actually, and working to a solution.
I am getting a different error on the website. I am getting "An unexpected error occured" 75% of the time when the maps try to load. It is also taking around 30-45 seconds for the maps to display.
We are working on the performance issue people have reported around slow map load times
We fixed some mapping issues in SP1 and are still fixing a few. Till we get the next SP out, if you see the error again, just do what you did when you saw it this time
Verified that stopping and starting both services does remove the error.
while initially I was not seeing the same error, my issue was navigation from the Network Summary Home page would result in the page hanging (Not Responding)
Once restarted all navigation was restored.
Is anyone still having these issues? I'm on SP3 and I still get these issues 50-70% of the time. Its killing me. I'm going to have to roll back to 9.1 for a second time if I can't get past this.... HELP! I have a ticket open as well, but I'll try anything.Thanks
This did work for me as well. I have simply written a batch file to bounce those services and set up a scheduled task to do that every hour.Definitely need a permanent fix, but at least I don't have to roll back to 9.1...ugh!
HERE is the .bat file contents:
net stop "SolarWinds Information Service"net start "SolarWinds Information Service"net stop "SolarWinds Orion Information Service v1"net start "SolarWinds Orion Information Service v1"
SP4 is out, FYI, you may want to apply
FYI - I have just seen this and I'm running SP4.
Please apply 9.5.1 and if this still occurs, please open a support ticket so we can investigate
Actually, I installed 9.5.1 last Wednesday (1/27) and had no apparent issues until this morning.
Now, I"m seeing this, even after Service stop/start AND a complete system restart.
What the heck is this about?
Hey Ninja--
Love your avatar, btw. Go ahead and open a support ticket on this one.
M
I am having this error when reviewing the polling engines and also get the below error when trying to access the Events, Alerts and Syslog pages.
The Orion website is currently unable to display this page. Orion polling and alerting services often continue running, though this page cannot be displayed. Please take the following steps to attempt to alleviate the issue:
Please notify SolarWinds of this error. We will address and help you fix the issue.
Your specfic error is:
The message with Action 'schemas.solarwinds.com/.../GetNetworkDeviceNamesForPage' cannot be processed at the receiver, due to a ContractFilter mismatch at the EndpointDispatcher. This may be because of either a contract mismatch (mismatched Actions between sender and receiver) or a binding/security mismatch between the sender and the receiver. Check that sender and receiver have the same contract and the same binding (including security requirements, e.g. Message, Transport, None).
I would either upgrade to 9.5.1 or 10.0 which was recently released
