AARRRRRRRRRGGGG!!!
They still show as DOWN !!!!!!
What resource are you looking at? I just added in 10.0 an external node to google.com and added the down nodes resource and it does not show in there.
That is the default DOWN NODE resource with no changes.
Was this external node in there prior to the upgrade to 10?
Can you try a couple things for me
1. Add a new external node and see if it shows up there
2. remove and re-add the down node resource
A new external node does the exact same thing.
Yes and it does the exact same thing.
Something for sure is whacky going on with your install since upgrade to RC3. Just for grins did you try to re-run the configuration wizard. I know your wireless went away and other stuff when you upgraded to RC3 and we are not seeing similar reports elsewhere. Regardless, let's hook up Monday am and look into this.
OK sounds good. I have 5 or 6 tickets in right now so if we could get some concentrated attention from you guys for a bit on those that would be awesome.
Just FYI I ran a full on repair and nothing changed so far.
Did anything change after you removed the Profiler eval per your other post?
